redneckrothrock
Help please Greasytee.
I have a 05 Hino 165 in the shop with a jo5d-ta in it. It is a farmers truck with all the ugliness that implies. I was told he thought "they" over-reved it but the wrecker driver said it had been to 3 shops recently and 2 had worked on the top end. 2 or 3 castings that hold the rocker shaft down along with a 1/2 dozen cam/rocker bolts are broken and a bunch of the caps on the end of the adjusting screws are blown off and scattered. Looks like all [?] the damage was on the back 2 cylinders but I'm sure the entire valve train was "overstressed". I'm afraid this could turn into a complete overhaul which would probably exceed the value of the truck. Looking for some advise. How tough are these things? Can the pistons withstand some valve slamming? How about the rods? Crank? How expensive are the head parts? I don't want to waste a lot of time tearing into this thing if there is a good chance it will need a complete overhaul, I would rather spend the time looking for a used engine. Thanks for the help, you do good work here.
