That's the most common one.Here is a picture of the SCV on my truckView attachment 11857
Of course, if your dealer has never sold one, they probably won't have it in stock (which is ridiculous).
Is there much difference between 22100E0101 and 22100E0102
Is the dpr graph at 5 bars? Then yes, manual regen. If not, that's a maintenance reminder. Replace the inlet and outlet sensors on the DPR and have the exhaust brake adjustment checked. Have any open recalls performed.Quick question... We have 2010 Hino 258. Our tow department isn't exactly on top of letting our service dept know when issues arise. We recently had it in our shop for a routine LOF and noticed on the message center it simply says DPF. No other indicator lights are on. We have scoured the entire building for the owner's manual and cannot for the life of us locate it.We are curious as to what this means and if we need to perform the manual regen procedure.
Thank you in advance and we are working on purchasing a new owners manual.
Inspect itv, replace if in question. Modify it, whether new or used.Working with a 09 268 w/200k on it. no code / drivability issues. It has been to two other shops and the dealer and they can not find problem. I has no power and pops thru intake, bucks and surges under acceleration. Any ideas? Passes all of the dx tests in hino explorer. The only spec out of range I have found so far is turbo boost is around 10 psi, 15 psi is spec if I recall. Again any Idea? I rarely work this product line.![]()
Have a 04 268 dealer said turbo was causing power lose. Changed same thing. Drive it and it loses piwer and smokes. Pull off road let it idle. It will be good again for 20 miles or so then smoke and lose of power. Checked fuel system. Good. Any suggestions?Hi all. I've been working on Hino trucks almost exclusively for the last few years, and I'm pretty familiar with their ins and outs at this point. If anyone has a question, I'll be happy to answer it, if I know the answer.
Here is the information on the Supply pump located beside the SCV
Did they blame low boost? Do you know what codes, if any, it was showing?Have a 04 268 dealer said turbo was causing power lose. Changed same thing. Drive it and it loses piwer and smokes. Pull off road let it idle. It will be good again for 20 miles or so then smoke and lose of power. Checked fuel system. Good. Any suggestions?
I'll double check in the morning (if I remember. I've never been this busy).Here is the information on the Supply pump located beside the SCV
Supply pump 22100E0100 ( SCV kit 04226E0100 )
Auto or manual transmission?A follow up to my last post, I am not real comfortable with this dealer because they also told me I need a starter, the starter relay was getting power but I believe there to be a second fuse panel because the starter jumped right over with no drag what soever
