To confirm, it wants to manually regen every 350km because the DPR graph hit five bars, correct?
I'm going to split this into three parts: What might be wrong with it, items that you can check and replace without needing Hino DX software, and what I would check if it was sitting in front of me.
What's wrong: Incomplete regen, failure to auto regen, low power, CEL.
U1123 CAN communication lost between ecu and VNT controller
P0102 Air flow sensor circuit low input
P0113 Intake air temperature circuit high input
P0088 High rail pressure
P0088 basically only shows up when the SCV (suction control valve, aka fuel pressure regulator) starts getting stuck. I would just stick a new one on. It's a pain in the ass to reach. I have a 5mm, 6 inch long ball-end allen driver that I use to get it out.
You will want to get the p/n and s/n off of the fuel pump so they will give you the right one. Or take it off and carry it into the dealer parts department. Yours may be an early scv, which means the kit will come with a small adapter plate. If you get the wrong one, the truck will be completely undriveable.
U1123 means that the ecu has lost communication with the VNT. This is less common than P0045, which means the ecu has communication with the VNT, but the VNT doesn't react properly. I have replaced turbos because of relentless U1123 and that has fixed the problem, but I've also addressed some more fundamental electrical issues (which we'll get into in a minute) and that has solved U1123 for just the cost of time.
P0102 and P0113 are related in that the maf and iat sensors are both contained within the same sensor. The deal here is that these are pretty tough and I'd suspect a possible harness problem if a temporary test with a new sensor didn't fix it immediately.
Failure to regen:
Let's just pretend that P2002 DPR malfunction is on that list. Because it is, in spirit.
A manual regen every 350km is absurd. An automatic regen is taking place every 150km. Whenever the DPR gauge hits three bars and the vehicle is moving, it's going to attempt an auto regen. your truck should complete an auto regen in less than 10 minutes of driving, maybe as low as 5. If you were constantly on the move, you might have thousands of auto regens and no manual regens.
Question: How long are your idle times?
Question: Do you leave the exhaust brake on all of the time? It should be treated like a one-time event, rather than being left on constantly.
For an auto regen to be successful, the intake throttle valve needs to open most of the way, the VNT needs to limit boost, the mass airflow sensor needs to accurately calculate how much air is going into the engine, the EGR valve needs to shut most of the way, and the injectors need to be in half decent shape. Post injection will heat up the Diesel Oxidation Catalyst (DOC), which will heat the DPF up enough to support combustion. When that temp is reached, more air is introduced with less post injection, and the soot burns out of the DPF.
A manual regen is similar, but the ITV shuts some to limit airflow and the exhaust brake shuts. The amount that the exhaust brake closes is critical, and as the injectors age, the brake needs to be adjusted to compensate.
Part 2 coming up.
