JGMMDURAMAX
Check engine light? Any codes? You can actually look up codes on this truck. Press the mode button in until a sub menu pops up. Tap up on the toggle switch until you hit 'self check'. Tap down to select. It may say "no codes". Hold up on the toggle until codes appear. Tap up(or down, I forget, just make sure it's a tap and not a hold) to cycle through them. Write down the recent ones and post them here.
If the truck doesn't think the brakes are applied, and the intake throttle valve isn't slamming shut, then the next thing I'd look at are how well the suction control valve responds to commands from the ecu. This is impossible to determine without software. You can throw one on for the hell of it, but that's a $250 guess (and it's a pain in the ass).
Occasionally we also see turbos that are completely worn out physically stall and create an airflow restriction. Yes, that has actually happened more than once.
Does it shift correctly once it gets going?
Back to the brake switch (because this problem is pervasively common). Unplug it. Does the truck accelerate normally? Now run a jumper wire across the terminals in the harness. Does it accelerate correctly?
Here are the codes, Jul 11 U1123, Jul 9 P0102 P0113, Aug. 7 P0192 P0088
June we replaced the turbo due to the turbo squealing and lack of power , replaced it
with a rebuild and balanced turbo
No turbo squeal but still having a lack of power and shift points, engine light and would not rev up and going into limp mode
Took the truck to the Hino dealer in Winnipeg, Beaver Truck. and was told it was the turbo actuator and truck will need a new turbo.
Got hold of MS Turbo who supplied the rebuild turbo, and explained a VNT actuator was needed, they shipped a replacement
Installed the replacement VNT actuator and no change still a lack of power and shift points and engine light and limp mode
Returned the truck back to the Hino Dealer and a NEW turbo was installed did this solve the problem NO it did not and $4000 later for a new turbo
The engine light is still coming on and still not rev up and in limp mode. and we are now in the month of August
Had been resetting the ecm by disconnecting the battery cables and taking notice the truck engine light was coming on only when the Econ/Power switch beside the shifter had been in the Econ switch position for the engine light to come on placing the truck back into limp mode
When the selector switch is in the Power position no engine light no limp mode but still having a lack of power and poor shift points and a new Hino turbo the VNT controller that was told would fix the problems and it is now August 22 will be returning the truck back to the dealer
