I have worked on my own cars with the help of repair manuals but never on a truck and never on a diesel.
Well, let me tell ya, there's never a time where something is not broken on a truck.
Every truck is broken. Even brand new ones. Something is awry. The wise person regularly combs over their truck and looks for this thing.
Check the fluids frequently, along with the tire air pressure. A big truck is absolutely willing to blow a tire at its earliest convenience. A tire 20% low on air is a prime candidate for blowing chunks of rubber all over everyone behind you, and it won't have looked flat at all. Gotta put a gauge on it.
Every time you change your oil, get up under it with a grease gun and a fresh tube of grease and look at everything. Brake pads. Leaf springs. Loose bolts, cables loose, leaks, everything. Something, somewhere on that truck is messed up and it's your job to find it.
If nothing else, you'll find corrosion growing on the battery terminals, so you'll want to clean that off. Not just squirt some stuff on it, you want to remove the cables and actually clean all that crap off of there.
You're gonna use that whole tube of grease.
Change the fuel filter, too. Drain all the scum out of the fuel/water separator. This is ignored far too often.
Do this every time you change the oil. 10,000 miles seems like a nice round number.
If you plan on doing a lot of the work yourself, you're gonna be faced with a couple of expensive tool purchases. These can pay for themselves very quickly, but the initial shock of the cost will sting for a while.
