Multi-function. The stalk. You found it already. No one ever calls them multi-function switches.thank you for the quick reply. the truck did not even attempt to crank. when i turned the key, it made a sound like a dead battery... a very loud "CLICK" and then nothing. there was no cranking attempt. However, a minute later after i turned the key, it fired right up on the first turn of the key and ran great all the way home.
I am dying to figure out how to turn that engine brake off, i dont want it on LOL. please also forgive the stupid question, but what is the "malfunction switch"? is the engine brake control located in the same area as the wind shield wipers? If so thats probably how i turned it on as i was hitting every switch in the cab to see what they all did.
and yep, thank you very much for the tip on the engine brake. i went outside and sure enough just had to move the wiper lever up. THANK YOU!
You probably just have some ultra-crappy battery connections. Common issue. Instead of dicking around, yank both batteries out, load test the
![Censored :censoredsign: :censoredsign:](/forums/styles/eo/smilies/censored.gif)
