hello from quebec...
heres my problem with my 238 2005...
when demanding power,the engine cuts with a series of 3 then become very smoky from the exhaust until i reach my cruising speed.
if up shifting at high rpm the engine performs well but,if climbing a hill,running with a load on the plate (its a tow truck),shifting at low rpm, it cuts mostly 3 short times 90 % of the time...then ,after it as done it ''cuts'',theres a loss of power and get smoky
The fuel filter is new,ive change the egr module (block with 2 egr valve on it) without success...
I went to hino dealer yesterday and theyve plugged the computer on it...We can see the fuel pressure graph that its actinc like a yoyo all the time...up down-up down steadily...
it does that cutting mostly around 80-90 kmh.
Ive by passed the fuel filter to check for a leak on the filter holder...no luck.
any ideas ?...seen that problem before ???
sorry for my writing,im french so hehehe
any help would be appreciated...
cheers
engine info's
model JO8E-TA
ID 4HMXH07.7JTA
469 C.I.
220 hp @ 2500 rpm
and 490 000 km
