Yea its a Hino dealer here in Fl. Thanks for the info I know a few weeks back I was running around 65 and a little Hino passed me and was gone so he was hitting at lest 75 +
As far as the maintenance I will do the oil change / Fuel filter / Air filter. About how many miles till it will need a dealers service work ? Also he was saying to keep a eye on the water fuel thing on the side of the cab and make sure to run good clean fuel too.
Ron.
Hinos really, really like clean fuel and fresh filters. It keeps the injectors in good shape. Their recommended intervals are something like 20k miles, but we've seen some engine wear with oil change intervals pushed that far apart. Besides, they only hold about 12 quarts of oil. 10k mile services are what I'd shoot for.
The fuel filters on these are frankly a bit ridiculous. There's a few pretty delicate o-rings involved, and mashing it together causes leaks. Air is easy to trap in the filter housing.
To avoid these problems, we do this: Completely remove drain screw and filter cap. Drain entire fuel filter housing. Replace o-ring on drain screw, reinstall. Replace filter element. Replace o-ring on cap. Lubricate o-ring on cap with engine oil. Set cap on fuel filter, use center bolt to draw the cap down. For some reason, any attempt to press the cap in place then threading the bolt in will cut the o-ring. Every time you remove the cap, the o-ring needs to be replaced, or it will leak. At this point, remove the bleeder screw, replace the o-ring, lube 0-ring, but before reinstalling it, work the primer pump until bubble-free fuel comes out. At that point, install the bleeder screw.
At the shop, I hook a mityvac suction pump up to the bleeder screw to draw fuel through the system and pull all the air out.
If the bleeder is removed while the engine is running, it will quickly bleed the system, and also cause a green diesel fuel shower all over you and anyone standing nearby. Not that I have any first hand knowledge of that or anything.
Anyway, it's not so bad after you figure out how to do it. A long crank time indicates that there's still air in the system, and more bleeding is required.
Your dealership sounds kind of...slow. They should know these things. They should know how to set the speed limiter, and they should know how to fix the exhaust brake, and they should know how to get paid to do it under warranty. They should fix all of this to your satisfaction before you give them any money. My two cents.
