Well, I have not driven my truck in the last month or so, its sitting in the parking lot of where I work now, we used it to move the business. So the other day I got in there to start it for a few, and turned the AC on because I was hot, and the AC didn't engage, the compressor was just barely moving, like the coil was not pulling it in all the way. I turned it off, figured I would check it out this weekend. So im tracing things down and when I use my voltmeter I am showing about 12.06 volts, when the truck is running, it takes me a minute to realize, that's not right. The alternator light was not on, but when I turned the truck off and the ignition back on, the light didn't light up at all. I checked the 140 amp fusible link and its ok, there is voltage at the alternator, so is the alternator internally regulated or could the problem be somewhere else?
Figured I would see if there was something easy to check before I pulled the alternator off, any help would be awesome, thanks!!!!
By the way, its a 2005 Hino 268
