Or Eb, here is the alternative point blank! John hires cargo vans! The rate is 90 cpm! Your 1st out in Laredo but 2 cargo vans behind you guess what??? Just because you didn't wanna play the game and the 2 behind you that did means your still in Laredo!!!Have fun brother! If your industry is changing either change with it or fall behind!!! Dont get this twisted, because trust me there are plenty of times we can still run the way we do, just not as often as we used to!!!We've been spoiled, so let's not be blinded here!!! That's all I ask.
Sent from my LG-D950 using EO Forums mobile app
That does not apply to everyone. Some wouldn't be bothered by still being there. The loads got covered by the other two trucks so the coverage problem doesn't exist till the next load is offered and turned down.
You are rite that the industry is changing. But it's changes don't effect everyone in the same way. I'm pretty sure Eric does his part to help out, takes good paying loads and less desirable ones. Everyone should have a number that they must have to keep their business solid. That is one thing that is set and can't be changed.
As as I said, there is no one size fits all. You have to pick a starting point and progress and adapt from there. It's better to be proactive. Seems like we have a good starting point just have to see where it goes.
Another thing to think about, which nobody has mentioned, lost revenue. Not just yours but Johns also. what effect will it have on johns bottom line. Lots of things to take into consideration.
