See the definition of what constitutes a declarative sentence.See Thread Title
I wrote what I wrote ... your interpretation/understanding of it is faulty however.You did write it, specifically.
Yes - that is one use of it ... but it's not the only one.True enough the "or something" implies and allows for an infinite number of possibilities, but only right up to the point where you slapped a colon at the end of it. A colon is used to explain or start an enumeration (to mention separately, a list, specify one by one).
Wrong.You enumerated no other possibilities, and thus allowed for none.
Again: my humble apologies to the grammar and punctuation gods ... whoever they might be ...Rule 4
Use a colon instead of a semicolon between two sentences when the second sentence explains or illustrates the first sentence and no coordinating conjunction is being used to connect the sentences. If only one sentence follows the colon, do not capitalize the first word of the new sentence. If two or more sentences follow the colon, capitalize the first word of each sentence following.
You might be onto something there ...You just have to be right...and have the last word...
I'm well aware of what a declarative sentence is. Your thread title was split into two parts, connected by a series of periods (ellipsis) indicating a pause and flow of a sentence, ending with a colon and the following enumeration. It's all one declarative sentence, all one statement. It's a common way to start a thread or post a reply (when using the thread title as part of your sentence), and there's nothing wrong with it.See the definition of what constitutes a declarative sentence.
Hint: Noun phrases (?) that comprise some portion of the sentence's subject don't qualify AFAIK ...
If your sentence had ended with a period, you're right. If you want to squeeze out the meaning from other uses of the colon, then those other possibilities can only come from the object of the sentence, and not from anything within a prepositional phrase. We're left with "sin" or something else of the father. In either case, the father did it. More possibilities, but hardly infinite.Further the use of "or" would seem to indicate the possibility that the thing preceding it was declared only as a possibility ...
You wrote something with a specific syntax which conveys a specific meaning, and now you want to blame the reader because they failed to recognize and understand that syntax to mean something that you didn't actually write? Really?I wrote what I wrote ... your interpretation/understanding of it is faulty however.
No, it's not the only one, but it's how you used it. Intentionally or not.Yes - that is one use of it ... but it's not the only one.
If that's true, then what you did was state as a fact that the sins of the father, or something else the father did, caused the suicide.Wrong.
I used it in the syntactical-deductive where:
The colon introduces the logical consequence, or effect, of a fact stated before.
Well which is it? A logical consequence of an effect of fact stated before, or an enumeration of the effects of the fact you gave?One might posit that in lieu of actual facts, possibilities might be allowed as well.
Apology accepted. But the only sin was arguing pedantical exactness (allowing for other possibilities) when the same pedantical exactness you penned made such allowances impossible.(If this is totally outside of the realm of acceptable grammatical construction and usage, then I hereby submit my humble apology and ask for forgiveness for the grievous sin of improper grammar ...)
I'm quite sure at this point that that's what you meant to say, or convey, but the colon nevertheless changed that meaning. As stated without a colon, the "something" still refers directly back to the object, "the sins," or something else the father did. The colon gave us the only enumerated possibility. Other suggested uses of the colon don't give us the meaning you were trying to imply.The possibilities stated were "The sins of the father ... or something" (undefined, particular specifics unknown)
It might be the logical consequence of what you were trying to say, within the limited scope of the sins of the fathers, but for it to be a logical consequence, no assumptions can be made. If the possibilities were, and remain infinite, then no logical consequence can be reached at all, only speculative guesses. Logic is the use of valid reasoning or argumentation in some activity. If you wanted to discuss the possibilities of cause and effect, you probably should have stated them as possibilities instead of flatly giving us the cause and effect.The logical consequence was the suicide.
The possibilities were, and remain, infinite.
Well, if you used it under Rule 4, then you are again back to the only possibilities being the sins of the father or something else the father did which caused the suicide, and not an infinite number of possibilities.Further, from Colons Punctuation Rules:
In my initial reply I even gave you the benefit of the doubt as to allowing more possibilities, but your reply to that right quick narrowed down the possibilities to being only that of the effects of the sins of the father, clearing up any possible misunderstanding of the use of the colon to be anything other than that of the onset of an enumeration.
Thank you for your usual Johnny-come-lately insightful input into a thread.My Lord, you misinterpreted what the man was implying and he has exhaustingly tried to explain it to you. Let it go already, you're looking quite foolish at this point.
And you're trolling.Your smarter...you win!!!!!!!!!!!!!!!!!!!!!!!
#lastwordgestspo
Your first post in this thread was made solely to attack me, and now you're whining? Don't dish it out if you can't take it.I didnt think ; the moderators job ` was to : put members down )in o obvious ) attempt to raise the self esteem ¿
Does"nt seem good for business,
#crybaby
No..it was to point out your out of control ego..really you have to write 3 paragraphs about proper punctuation...
No crying here...just the facts..
Ahhh ... when ya get a second and can spare a moment:Telling me what you attacked me about doesn't make it NOT an attack.
Just so we're on the same page:
What is the prepositional phrase that you believe I'm trying to "derive meaning" from?
Well, yes ... it was something: a simple question, posed to ensure that I understood what you were referring to.Sorry. I thought it was a trick question ... or something ...
Fact is, I know of very few suicides are the result of what one's father did. I know of none, actually.
Yes, a person of authority which you attacked for no other reason than you wanted to attack me unprovoked, and you didn't like it when I responded in a manner which hurt your feelings.You can call it anything you want...again pointing out that YOU are person of authority in this little online world....
