Don't you still use your shoe phone???
I actually chuckled at that...thinking Maxwell Smart and 99...and Joes' spying career....
The exact procedure depends on your phone, but basically you have to get into the Service (or Test) Menu, where you can change all kinds of parameters, like forcing the variable rate Vocode (voice coding quality) from EVCR to higher quality 13k encoding. EVCR uses a variable bitrate to encode, and utilizes more error correction, so in weak areas with a lot of RF interference, your voice could be slightly garbled for a bit. The variable bitrate can be anywhere from 2k to 13k, with 8k being the norm. Not all networks support EVCR, and will default to 8k. EVCR uses less cell tower capacity than the constant rate 13k does, which is good for cell phone companies in that they can have more capacity per tower, but it generally degrades the voice signal when it suburban and rural areas by using a lower bitrate. Mine is always set to 13k. YMMV.How do you get it over to cdma only?
You can even change how often the phone "seeks" a cell tower to check for an incoming call (too slow and you get phone calls without the phone ringing or you miss a lot of calls, too fast and you run your battery down too quickly). Rather than mess too much with that one, I just got an extended battery. But on older phones where I didn't have an extended battery, it increased battery life considerably.
You can force it to CDMA from here, as well.
On my Motoroloa v9m, you press #073887* and then press the 6 digit security code (almost always six zero's, unless you change it for some reason), and you will get to the Service Menu. That's where you can change some of the parameters, none of which I'd recommend you changing except the Vocode, and if you want to change it to CDMA-only, you scroll down to the Test Menu option and enable that. Once you exit out you are in the Test Menu where you can see the blood and guts of the digital innards of the phone. Press to the right a few times and you'll get to a screen that looks as geek as the others, but you can then scroll down and change the "auto" to "cdma" for the HDR Pref setting. The phone will then be permanently set for CDMA, unless you go back and change it, or unless and until you update your PRL with *228.
There are detailed step-by-steps to do these and many other wonderful things to your phone at Howard Forums. Grind down the forums to get to your particular phone manufacturer and model, and then look at the sticky's. It's in there.
Forgot to add this to my original post(s). I-Phone has the Apple browser "Safari" already installed. While it is somewhat difficult (though possible) to browse most websites, because some of the signatures are so incredibly long, i.e. layoutshooter, it renders the browser on the I-Phone useless here on EOL.
Truth be told, while I read most posts, those with the very long signature lines I tend to skip over. They have gotten so long and out of control, that I have to scroll down several times just to get to get past someone's over-inflated ego.
Kind of like those whose "tat" their bodies up like a carnival freak.
"Look at Me. I need attention."
LOL
Really ? .... that's funny ... because I have used it many times to browse and read EO ......I-Phone has the Apple browser "Safari" already installed. While it is somewhat difficult (though possible) to browse most websites, because some of the signatures are so incredibly long, i.e. layoutshooter, it renders the browser on the I-Phone useless here on EOL.
Lawrence,
A really dumb question, what would the app do?
I can't see what other than a branded app which is cool but what?
Greg,
We would make the iPhone serve our News, Forums and Classifieds in iPhone structure.
Technically, yes .... they do.Another dumb question for iphone users, do all the apps have to be loaded through Apple?
Yup .... battery life when actually using the phone could definitely be better (on standby it is pretty good) ..... it would also be nice if the battery was user-replaceable.I do have a dislike about the Iphone 3G. The battery life. This is the first phone I've had where I talked past the battery life ....
Yeah .... apparently there are a couple of different apps or hacks that will accomplish the feat - some require "jailbreaking" the phone. There was one that was posted in the App Store for a short time that I believe did not - don't recall the name of it - it was pulled shortly after it became available.There is a app for tethering, but I haven't tried it.
Kewl !Had the new version for about two months. Seems to work well and haven't had any drop calls yet.
