Turnpike decides to roll out E-ZPass, new rates on Oct. 1
Doggie Daddy
Watch your bill when you do that, mine has worked from under the seat and from inside the glove box in my wifes car........
You are so right chef,we had an old I pass that we were no longer using after they started accepting EZ pass,it was under our seat and 3 different times was picked up by the NY toll readers.
Bad part was there was no money in that account,so not only were we getting dinged for the tolls,but for not having the funds to cover it.:eek:
A Plus Expediting
A Plus Expediting
(937) 424-0220
Advertiser
OTR SPRINTER VAN OWNER OPERATOR
Are you looking to put your superior driving skills to good use? Do you have an extensive track record of clean and safe operation, timely delivery, and dependability? If so, then this driver’s position could be perfect for you. Successful drivers communicate clearly with dispatch, deliver product on time and safely, and can perform these roles w ... Apply Today!
60MPH
Wrap it in aluminum foil it keeps the towers from reading it. It also keeps the aliens from knowing where you are:eek:
Slo-Ride
Overheard a conversation at the Des Plaines oasis while waiting in line at the I pass service desk. Service rep stated to a trucker that Illinois State Police, "can", and do check the I Pass system when they pull you over to verify log books if they see fit. Just another big brother for them to use against us if we have fudged a little
Any time theres a paper trail of your trip ya gotta be careful when coloring in your books..Dont forget the time stamps on your bills also..
Jack_Berry
Moderator Emeritus
ohio tp weighs every vehicle coming into a booth. last nite i exited at 280 and the fee was 3 dolla and a class 1. later i exited the t-p in youngstown and the lady said $9.25. i handed her $10.25 and said you mean $7,25, right? no you were weighed and are over 7000 lbs. class 2. i said i had a ticket from toledo showing class 1. well it did not matter. class 2 and $9.25.
oncedrove
It's real easy weight more on those scale IF your braking going over them.
Jack_Berry
Moderator Emeritus
the problem is i never saw it. its not like crossing the border to the usa. that is a scale. does ohio place sensors in the pavement? could the vehicle behind me be on the scale when i weigh?
Trailblazer
The Ohio Turnpike is in the process of reseting all of their scales in anticipation of EZ Pass. Once EZ Pass goes into effect, you will not know your class until you look at your billing. I have always been a class 1 until the past month. My van weighs exactly 6960 with a full tank of fuel. 9 out of 10 times I now get a class 2 ticket. If this happens to you pull over outside the booth and ask for a re-weigh. (I carry a recent CAT scale ticket with the fuel receipt showing the tank was just filled prior to the weigh) If they refuse, ask them if they a prepared to go to court and face a class action suit. They will let you re-weigh or give you a class 1 ticket.
Jim
Jim
Since it was announced Ohio is going by number of axles, maybe what you saw was a dismantling of the scales?
Trailblazer
The toll collector told me that they we re-calibrating their scales over the last month. So they must be trying to get their money as quick as possible before it goes into effect.
Jim
Jim
Those scales were anything but accurate....with a sprinter with any decent weight load I'd be over 7,000 and not get dinged and then with only a couple hundred Lbs I'd get tagged for class 2 and then I'd do the re-weigh thingee....
