Phil,
That is some awesome info on truck specs !!!!! I found several things I was considering such as tires, and rear axle ratios, your Air glad hand trick is something I have already rigged on may a truck, not only can you air tires but clean the box, cab of truck, air dry after a wash etc...Im more torn on Engines and Longevity and repairs of them, I am a fan of Cummins Engines, and the Allison 3000 Series road Auto trans. You rig is quite a bit larger then what I want, going for a Lighter truck for fuel economy and I just dont need the extra load caps,
As far as sleepers go I doubt Ill have quite as much but I do plan to have some comforts of home, desk, computer and Large screen TVs, I like the Security system Idea. I do some security work and have lots of contacts for this kind of thing, a back up cam and a front mounted cam I think will be added, security is important today and recording accidents or ignorance on the highways is a good thing.
I want to do the same and spec a LONG LIFE vehicle, Ill look at some components that are over rated for the same reasons longevity and durability. The Box and Liftgate, all will be designed for long life and use prem components such as added floor joists for forklift, deck plates, scuff liners etc, I come from a background where I used to build trailers for Great Dane and Freuhauf, so Ive got a little knowledge as to whats TUFF and whats crap....and 1/4" thick cheap plywood isnt worth installing, and using 3/4" in the Nose of the Box to prevent the punch thru's.
What brand tires do you use, Ive been leaning to the Michelin Pilots, Ive used Michelin on most of my vehicles and found them to be very good, but Ive heard of a tire called GT Tires supposedly an Import thats a decent Drive tire, do you prefer a ALL Season radial, or a ribbed or traction tire...????
