Ok, while i was out west messing around, I installed a "bugshield/deflector on the ft edge of the hood of the Cargo Max..Now...as ifigured it would, but it is worse then I thought it would be..the thing takes air off the windshiield anf the wipers do not do the job the did before..they are new blades and the arms still have good tension...so...has anyone ever drilled a few well placed holes in one of those shields to let some air pass through to get more air to the windshield?? If so how did it work? If not, does anyone see whay it wouldn't work??
To correct the problem of changed airflow to the windshield caused by the installation of a bug deflector, you need a product called "Wiper snuggies", often found at most chrome shops, and a few select truckstops.They really do work.
Also, the presence of winter-wipers will cause the wiper to lift off the windshield a lot worse than standard wipers will, in additon to the changed airflow caused by the bug shield.
The Petro shuold have these, of even the Lone Star Chrome shop behind the Petro, across from the shop, by the water tower where you are at, in El Paso.If you need a laundro mat, coming out of the Petro, go south on that road, to the end, and there is a strip shopping center in front of you.At youre right, that end of the strip shopping center, is the laundromat.
Loading for Monday morn Windsor del...be home for Mother's Day weekend..... Happy Wife, Happy Life!
Dale
I done like cats either...but...![]()
Please don't use cats to hold down your wipers![]()
Angie's dog had a litter of puppies. She asked me to take the last one she had. Just happens she's of the female persuasion. Her name is Cheyenne.
Sent from my MB860 using EO Forums
And the groundskeepers hubby is taking a nap.....
I was good, but then I knew you were sleeping...*lol*Now that Mark, Jeanna and Guido have called.....I am up....![]()
A Sprinter team brought in 3 pizzas for dispatch....which I followed in and scarfed a couple of slices...At the yard also, we will have to visit later. Come on Tim, you owe us one for the weekend. Met Steve this morning and chatted for a bit. Talked to boss man also. Cheese cake has bee stolen. Lol
A Sprinter team brought in 3 pizzas for dispatch....which I followed in and scarfed a couple of slices...![]()
You and MR Snappy left voicemails at the same time....I didn't see yours till this morning....sorryI called you lastnight but you didn't answer.
