Marijuana = alcohol
I never mislead anyone. Does smoking marijuana cause brain damage? Yes or no?
A YES/NO answer to that question would be an irresponsible answer. For the vast majority of people, the answer would be NO. For a very small number of people, under certain circumstances, the answer would be YES.
There were other studies done but the authors forgot when they put them on the way to the munchies store.
Integity isn't your strong suit imo Carl.
Well, coming from such a master of logical fallacy as yourself, I'm just ... crushed ... I'll tell ya ..
You can't even be honest with yourself - let alone anyone else - about your own mischaracterizations and misleading statements in this thread ...
Integrity ?
Shyeah, right ...
Maverick
Turtle;665198 It's someone who has cannabis abuse disorder, and got it when they were in their teens.
I've never drank and I've never smoked a joint (or any part thereof). So, it's not like I have a vested interest in this or anything. The only interest I have in this is personal liberty. I believe that as an adult you should be able to put into your body anything you want, be it alcohol, pot, a high fructose corn syrup Big Gulp, Lortab, salted bacon, or drain cleaner.
To that end, I get a little tired of these victimless crimes. It's a theme running throughout the founders documents, and want for true liberty. If you've harmed no one, and their is no victim.....there should be no charge. Jury's used to acquit over these things. Put the THC in pill form, and let em pop away....I say.
Beats the heck out of drivers with smart phones, or the persons so hyped up on pharma drugs they seem to have a lot of trouble doing simple maneuvers like; yield, merge, and lane changes. Switch them over to THC pills, get your kaleidoscope view of the landscape....and chill down man.
As stated earlier, I'm not necessarily against legalizing it, however given that doing so would increase enormously the amount of funny plants readily available for consumption on a much larger scale, you would agree that 'very small number' would grow into a much larger number. Not mentioning the probability of it on our young people would be irresponsible.
https://www.drugfree.org/newsroom/pats-2011
Here is an article on the study that coorelates heavy marijuana use and brain damage.
MARIJUANA USERS HAVE ABNORMAL BRAIN STRUCTURE AND POOR MEMORY
Drug abuse appears to foster brain changes that resemble schizophrenia
December 16, 2013 | by Marla Paul
The younger drug abuse starts, the more abnormal the brain*
CHICAGO --- Teens who were heavy marijuana users -- smoking it daily for about three years -- had abnormal changes in their brain structures related to working memory and performed poorly on memory tasks, reports a new Northwestern Medicine® study.*
A poor working memory predicts poor academic performance and everyday functioning.
The brain abnormalities and memory problems were observed during the individuals’ early twenties, two years after they stopped smoking marijuana, which could indicate the long-term effects of chronic use. Memory-related structures in their brains appeared to shrink and collapse inward, possibly reflecting a decrease in neurons.
The study also shows the marijuana-related brain abnormalities are correlated with a poor working memory performance and look similar to schizophrenia-related brain abnormalities. Over the past decade, Northwestern scientists, along with scientists at other institutions, have shown that changes in brain structure may lead to changes in the way the brain functions.
This is the first study to target key brain regions in the deep subcortical gray matter of chronic marijuana users with structural MRI and to correlate abnormalities in these regions with an impaired working memory. Working memory is the ability to remember and process information in the moment and -- if needed -- transfer it to long-term memory. Previous studies have evaluated the effects of marijuana on the cortex, and few have directly compared chronic marijuana use in otherwise healthy individuals and individuals with schizophrenia.*
The younger the individuals were when they started chronically using marijuana, the more abnormally their brain regions were shaped, the study reports. The findings suggest that these regions related to memory may be more susceptible to the effects of the drug if abuse starts at an earlier age.
“The study links the chronic use of marijuana to these concerning brain abnormalities that appear to last for at least a few years after people stop using it,” said lead study author Matthew Smith, an assistant research professor in psychiatry and behavioral sciences at Northwestern University Feinberg School of Medicine. “With the movement to decriminalize marijuana, we need more research to understand its effect on the brain.”
The paper was published Dec. 16 in the journal Schizophrenia Bulletin.
In the U.S., marijuana is the most commonly used illicit drug and young adults have the highest -- and growing -- prevalence of use. Decriminalization of the drug may lead to greater use.*
Because the study results examined one point in time, a longitudinal study is needed to definitively show if marijuana is responsible for the brain changes and memory impairment. It is possible that the abnormal brain structures reveal a pre-existing vulnerability to marijuana abuse. But evidence that the younger a subject started using the drug the greater his brain abnormality indicates marijuana may be the cause, Smith said. *
The groups in the study started using marijuana daily between 16 to 17 years of age for about three years. At the time of the study, they had been marijuana free for about two years. A total of 97 subjects participated, including matched groups of healthy controls, subjects with a marijuana use disorder, schizophrenia subjects with no history of substance use disorders, and schizophrenia subjects with a marijuana use disorder. The subjects who used marijuana did not abuse any other drugs.
Few studies have examined marijuana’s effect on the deep regions in the brain -- the ‘subcortical gray matter’ below the noodle-shaped cortex. The study also is unique in that it looked at the shapes of the striatum, globus pallidus and thalamus, structures in the subcortex that are critical for motivation and working memory.
The Marijuana and Schizophrenia Connection *
Chronic use of marijuana may contribute to changes in brain structure that are associated with having schizophrenia, the Northwestern research shows. Of the 15 marijuana smokers who had schizophrenia in the study, 90 percent started heavily using the drug before they developed the mental disorder. Marijuana abuse has been linked to developing schizophrenia in prior research.
“The abuse of popular street drugs, such as marijuana, may have dangerous implications for young people who are developing or have developed mental disorders,” said co-senior study author John Csernansky, M.D., chair of psychiatry and behavioral sciences at Northwestern University Feinberg School of Medicine and Northwestern Memorial Hospital. “This paper is among the first to reveal that the use of marijuana may contribute to the changes in brain structure that have been associated with having schizophrenia.”*
Chronic marijuana use could augment the underlying disease process associated with schizophrenia, Smith noted. “If someone has a family history of schizophrenia, they are increasing their risk of developing schizophrenia if they abuse marijuana,” he said.*
While chronic marijuana smokers and chronic marijuana smokers with schizophrenia both had brain changes related to the drug, subjects with the mental disorder had greater deterioration in the thalamus. That structure is the communication hub of the brain and is critical for learning, memory and communications between brain regions. The brain regions examined in this study also affect motivation, which is already notably impaired in people with schizophrenia.
“A tremendous amount of addiction research has focused on brain regions traditionally connected with reward/aversion function, and thus motivation,” noted co-senior study author Hans Breiter, M.D., professor of psychiatry and behavioral sciences and director of the Warren Wright Adolescent Center at Feinberg and Northwestern Memorial. “This study very nicely extends the set of regions of concern to include those involved with working memory and higher level cognitive functions necessary for how well you organize your life and can work in society.”
“If you have schizophrenia and you frequently smoke marijuana, you may be at an increased risk for poor working memory, which predicts your everyday functioning,” Smith said.
The research was supported by grants R01 MH056584 and P50 MH071616 from the National Institute of Mental Health and grants P20 DA026002 and RO1 DA027804 from National Institute of Drug Abuse, all of the National Institutes of Health.*
If anyone doubts the negative impact of marijuana smoking maybe they should look at Jeff Spicoli.
Question for the day: A 17 year old kid. He has one 'drink' of alcohol or one phily blunt each day. Which one is more likely to cause brain damage? Discuss...
There is currently not enough conclusive evidence to draw a conclusion based on those amounts.
One can assume that if they are 17 year old kids that they are brain damaged by nature. That is what leads them to drink and smoke dope in the first place.
For the purposes of discussion, let's disregard the illegality of the actions of our hypothetical 17 year-old kid. Let's also consider a concept that few 17 year-olds understand today - PERSONAL RESPONSIBILITY. If the above teenager can take one drink or smoke one doobie on a daily basis and be satisfied with that limit he's probably going to be OK, and no worse off than smoking one cigarette per day. How about making a 20 mile round trip to school on his motorcycle without a helmet, or in a car without wearing a seat belt? Is there more likelihood for brain damage involved with those choices? So long as people like this are making informed decisions, let them do what they please and assume the associated risks / consequences.
Lack of parental supervision might also be a factor, but let's face it - kids that age are likely to try almost anything once. The problems arise when there's nobody around to show them the errors of their ways. Today's family structure leaves a lot to be desired.
Yes, today's family structure, or lack there of, leads a LOT to be desired. Then, couple that with the natural brain damage of teens, and it becomes a recipe for disaster.
I get real tired of hearing about todays family structure as the root of our social problems.
Pot and alcohol usage within the younger generation has been an issue for decades, including most of our growing up years.
