As everyone should know by now,I'm no longer with FDCC,and really have no reason to stick up for their dispatch system.Before this system,each contractor had 10 minuets to decide if they wanted the load or not.This could use up enough time,that a customer could go to another carrier,by the time FDCC would get a commitment to a load.This new system,as much as it is being talked about,is not about getting a cheaper truck in the company.When ever you turn a load down,they want you to give a reason,and in that reason if you need more money,than you can list that too.The first person that would have received the load still gets the load,and yes,in any system,there can be a problem.Trucks from other than the express center the load is coming out of, could be dispatched,if they can make the pick up on time,and have more dwell time than the closest truck.As was stated earlier,you could turn down as many load as you want in a day,and still stay in the same dispatch order,this doesn't happen in most of the other companies.
