Id call around to rebuilders but I bet they'll only pay $50 if your lucky
Wow what a difference the injectors are not coded into the ecm yet and the engine runs as smooth as can be and even sounds different.
Yes I did, figured that was the easiest way.Excellent. Honestly, I doubt you'll notice much difference in the way it runs after having the codes entered, but I'd have it done anyway. Did you keep the sheets with the cal codes? Did you label them #1-#6?
Good. Otherwise the valve cover has to come off.Yes I did, figured that was the easiest way.
Those pressures are normal. At sustained full power it can drop dramatically if there is a restriction in the fuel supply. First replace the fuel filter and clean up the housing or sediment cap. Then pull all of the inlet fittings completely out of the fuel filter housing and look for debris. If none there, there may be debris in the tank. Not uncommon to find the 90 degree elbow in the top of the tank packed full of crud.My 2008 Hino 338 has recently had the check engine light come on twice for code P0087, fuel/rail pressure to low. My rail pressure is about 26,500-27,000 psi at 65mph and at idle its about 8000-9000psi. Are these normal figures and What normally triggers the p0087 code?
Yep it's the motor, with the ignition on but the engine off, it was getting power but not running, I tapped on the end with a hammer and it started running again.Usually it's the big relay on the side of the master cylinder frying. Sometimes its the motor. There is a big fuse in the external box powering the motor.
Does not look that difficult to replace only 2 bolts. Hope it's not that expensive....
Greasyshirt,
I asked a couple questions a while back about my hino 338 with 440k and got great feedback from you. "Thank you!"
My issue I'm having now is when stopped at a light with a small load (2,000lbs) or full load (17,000lbs) once I let go of the break and press the gas the truck just idles up 500-1000 tons and the truck will barely budge. Sometimes if you release the pedal and push again it will go, but at a super slow rate of rpm increase.
Today I was close to max GVWR and on a major highway in traffic and the truck wouldn't go up the tiniest of a hill.
I know this truck is close to beading a transmission... and I will throw another $5k at it if I knew that this would fix the problem.
At the dealer they have talked about some adjustment or replacing this part (possibly the pedal sensor?) which I've had them do both and still no fix to the problem.
Any thoughts on this?
Thanks again for your passion to all out Hino problems!!!
Hell if I know. $50?What's the typical price of these switches on the service break relay?
You have to remove the camshaft, so this is gonna take a while.How long does it take to do a Rocker gasket? I've got oil leaking from the right side of the engine above the exhaust manifold
