grape grower
Last time we talked, your engine blew up. What's the story?
Id pull the blower switch out and see if the contacts are melted.
The motor was replaced under warrenty, thank the lord, truck came with warrenty and I had 2 months left.
I took the blower switch out and flushed it with electrical contact cleaner, tried to pop the back of the switch off but got worried about breaking the plastic housing. I will get it out again and open it up. I thought I could remove the fan motor and give it the smell test but you are right, it has to be unbolted from the firewall side, trying to figure out how to get to the bolts without removing the air filter and the heater/air conditioner outside air intake. I unplugged the fan motor and connected a 12 volt battery (pickup battery with a good charge) fan ran for a few seconds and then stopped? I will get it out today and check it out. Is it possible to open the blower switch without breaking the housing? If the condenser pressure is low will the heater run as normal? i.e.: will fan motor run? The air conditioner has a 5 amp fuse (passenger /right side dash board) are there any other fuses in the system that i'm not locating? or fusible link (driver side-rear side of battery box and air tanks)? When the driver told me about airconditioner or heater not working I found a wet/ oily looking area on the front side of the condenser? Looks like a piece of gravel may have hit the condenser, after the truck sat for a while the spot was dry and no oily look or feel?
I appreciate your help, Thank You
