I have the CEL come on a 2010 Hino 268 that i just purchased a month ago from Penske. I had the code read which turns out to be P2002. I have had the DPF regenerated manually and the code cleared. After one day, the code shows up again.
How does the truck run?
When started cold, does the engine make a ruckus? Knocking, clatter, rough idle, sounds like it's misfiring? If so, how long does this last? A few seconds? Does it behave correctly only after it's completely warmed up? Does it run like crap all the time?
Take off the black hose between the intercooler and the intake manifold. Look inside the intake. You'll be looking at a throttle plate. Grab the plate and move it all around. Is the plate tight on the shaft, or are the screws loose? Can you move the plate in any direction other than opening and shutting the valve? There should be no play at all. There should be three holes drilled into the bottom of the plate, 3mm diameter, 8mm from the bottom edge. Do these holes exist? If not, take the throttle body (the intake throttle valve, or ITV) off of the engine and drill those three holes in it. I described how to do this a few posts ago. Also look at the "Hino Turbo" thread; I posted a picture.
When watching the DPR graph on the dash, does it suddenly jump up 2 or more bars at once? If so, check the DPF temperature sensor connectors, on the harness side, especially the front one, for breaks in the wire. You know how when a fusible link melts, if you gently pull on the wire and it stretches because the wire is broken inside? Kind of the same thing here, but the wire hasn't melted, it just broke because of vibration. These circuits might have to be load tested to determine if they're good or not.
When you had it manually regen'd, did they adjust anything? Has this truck had the A8440-A8510 recalls done on it? If so, they should have adjusted the exhaust brake. If not, have these recalls done. They are free. If neither of those is the case, the exhaust brake still has to be adjusted right, and the only possible way to do it involves using the factory diagnostic software.
How many miles does it take for the DPR graph to hit three bars? How many miles until it's crying for a manual regen? It sounds like it can't do an auto regen. Can it successfully do a manual regen?
