It might be, but what good is it to them if the carrier manipulates the FSC on a load by load basis?
Well if your contract says that your carrier gets 20% and you get 80% and they manipulate the FSC to take money from you then they aren't living up to the contract right?
That might not be important to you, but it might be to me. I would rather be in a situation where there are a few less grey area's to deal with, and that is what I have.
Granted, I have a lot to learn, but I can at least see something that has the potential to be abused...
thanks for all the info-i do understand bottom line per mile,but when shopping for carrier to work for they all throw out the numbers at you so many diffront ways. confusing to a newbe
The art of deception and confusion...
Many bids are all-in, but there are several customers where the bids are made on the line-haul only, and then the contracted FSC gets added in. Or they are all-in, burt the FSC is a predetermined amount of percentage. The reason for this, and why the carriers break it down, is because, for example, if your carrier takes 20% and gives you 80%, they are taking 20% of your FSC if it isn't broken down. But 100% of the FSC should be passed through, and then the 80/20 figured on the line-haul only. If they're taking their percentage out of both the line-haul and the FSC, then they aren't living up to their responsibilities. The FSC is a charge the customer pays to directly offset the cost of fuel, and if the carrier isn't paying 20% of your fuel, they are not entitled to 20% of the FSC. There's your gray area and transparency right there.So if it is an all included bid, why would the carrier go through the hassle of splitting it off when they pay the contractor? And why would it change from load to load? It just looks like a grey area, that isn't necessary...
How many people,other than John, really know the true rate ?
Are you notified when rates are renegotiated ?
If your rate is agreed to on a load by load basis aren't you always a load away from NO FREIGHT ?
The reason it changes from load to load is because the customers and the contracts change from load to load, along with the fluctuating price of fuel.
You don't mess with FSC with your carrier and are happy where you're at, and that's fine, but if your carrier is charging a FSC to the customer (and they are, even with all-in bids), and if they aren't passing 100% of it along to you, then that's abusing the system and you right along with it.
The attitude of "as long as I get what makes me happy, how much the carrier makes is irrelevant" is certainly one possible way to look at it, and if you're happy that's great. But it's a little short-sighted on two ways. If you get what you like and the carrier is losing money, that's not right or fair to the carrier. The reverse it also true, where if you get what makes you happy but the carrier is taking more than their fair share, that's not right or fair to you.
The reality is, you aren't out here to get what makes you happy, that's not what the cooperative partnership between owner/operator and carrier is all about. You are out here to pay the carrier a certain percentage of the line haul to find you loads, do the collections and forward you the money you are owed. They work for you just as much as you work for them, and most owner/operators don't want to pay a portion of their FSC to the carrier as compensation for what the carrier is being paid to do.
You think all customers are all charged the same FSC rate by all carriers? They're not. One customer may have 8 different FSC rates depending on weight, distance, dimensions, time of day shipped, origin and destination, and any combination of the above. It can also fluctuate greatly when all-in bids are won at higher or lower rates, and the carrier properly breaks out the FSC so as to not take a percentage of the FSC along with the line-haul.Then explain why FSC could fluctuate as much as $0.30 per load on the same day?
It's based on both fuel pricing and on existing contracts, but in any case, expediting isn't measured on a load-by-load basis, anyway. It's measures by the week, month, quarter and year. I've had loads with a relatively low FSC, and then the next load might be twice or more the "standard" FSC rate, whatever that might be.If it is based on fuel pricing, it shouldn't change that much, and what good is it if you can't depend on it to protect you on a load by load basis.
Well, that's apples and oranges. You're saying you's rather have an average rate to the truck at $1.85 than an average rate to the truck of $1.65, which is a "well, duh" moment. But using your 80/20 split as an example, and $1.85 as your happy-happy rate to the truck, would you rather have a load that the customer pays the line-haul of $2.3125 which when broken down is $0.566 FSC and $1.7465 line-haul, and 80% of each equals $1.85, or would you prefer that the entire $0.566 is passed along to you and then the carrier passes along 80% of the $1.7465?I would rather work with a carrier that is constantly getting me and average of $1.85 per mile without a FSC than a carrier that is getting me an average of $1.65 with a FSC...
Yeah, I know. I wasn't commenting specifically on your statement. I know where you're coming from. It was more of a general statement on the attitudes that some people (those who rarely look at the big picture) in this business have.My statements were based that if i were happy with the rate that an assumption the carrier got what they needed as well....
