I understand that this is a "FedEx" issue, but many questions are being raised that are EOBR issues not specific to FedEx.
I think that my concerns on who has access to data about my business and my truck are not “panicking”. I also think that if I want to go sight-seeing or shopping it is none of FedEx’s business. If you do, that is your opinion, so be it.
... We are currently a Panther team that uses the electronic logging. As long as you are not attached to a Pro then you can log 30 minutes of "off duty driving". That enables a driver to go to Walmart etc. On the actual log it will show a driver off duty. If you are attached to a pro then you are unable to do this ....
I'll ask the same question here that I asked in the FedEx forum, asking it about Panther's 30 minutes instead of FedEx's 7/10 of a mile.
I see no benefit whatsoever to the company in saddling its drivers with mobility disincentives that have no safety impact, undermine driver freedom and satisfaction on the road, and reduce the legally-available hours drivers would otherwise have to respond to load offers and haul freight.
There may be good reasons for the 30 minute rule the company is imposing and I am open to hearing them. Can someone explain exactly how and why 30 minutes became the magic number and how it benefits the company, the drivers and the customers they together serve?
EOBRs are sophisticated devices that can be programed to do anything the company wants them to do. Why was 30 minutes programmed in when the personal conveyance logging rules are so different?
For reference, the FMCSA personal conveyance interpretation is provided below (thank you, McBride for pointing it out). Source
Question 26: If a driver is permitted to use a CMV for personal reasons, how must the driving time be recorded?
Guidance: When a driver is relieved from work and all responsibility for performing work, time spent traveling from a driver’s home to his/her terminal (normal work reporting location), or from a driver’s terminal to his/her home, may be considered off-duty time. Similarly, time spent traveling short distances from a driver’s en route lodgings (such as en route terminals or motels) to restaurants in the vicinity of such lodgings may be considered off-duty time. The type of conveyance used from the terminal to the driver’s home, from the driver’s home to the terminal, or to restaurants in the vicinity of en route lodgings would not alter the situation unless the vehicle is laden. A driver may not operate a laden CMV as a personal conveyance. The driver who uses a motor carrier’s CMV for transportation home, and is subsequently called by the employing carrier and is then dispatched from home, would be on-duty from the time the driver leaves home.
A driver placed out of service for exceeding the requirements of the hours of service regulations may not drive a CMV to any location to obtain rest.
Why do you accept the EOBR units on your trucks....I can see it being forced on company drivers, but you are owner/operators.
You should have been given the option to chose which system...HOS, the ultimate responsibility comes down to each driver...Why do these companies feel the need to massage you along?
It is pretty simple..if a driver offends one too many times and effects the companies operating abilities, then terminate that specific problem.
It looks like all the solo straights will be running for ind. carriers, at least until they conform. Since it is very tough to serve 2 households from 1 truck, it appears this industry will become nothing but husband and wife teams.49 CFR 376.12(c)(1) requires a motor carrier using leased equipment to assume "exclusive possession, control, and use of the equipment" for the duration of the lease. If a motor carrier is issued an EOBR remedial directive, then it must install (or have installed) EOBRs in all vehicles it uses. Owner- operator vehicles leased to such a remediated carrier would be required to have EOBRs installed even if the owner-operator holds separate operating authority.
49 CFR 376.12(c)(1) requires a motor carrier using leased equipment to assume "exclusive possession, control, and use of the equipment" for the duration of the lease. Owner- operator vehicles leased to such carrier would be required to have EOBRs installed even if the owner-operator holds separate operating authority.
I understand that part....WHO made the decision to go with EOBR and WHY...
WHY did O/O's agree to this so easily?
I also was informed today by a friend that as a TVAL unit we are going to have to lease another piece of equipment too for like $70.00 a month. I am just trying to find out about that now....
I wonder if our politicians and carriers have stock in rental car companies?
