Countdown to Another Sprinter Killer- Sort Of
Speedwagen
"...They filled the tank with water and Vinegar (not sure of the blend)..."
And I am quite sure the ol' girls (trucks) smell "clean and refreshed" without any "embarrassing odors." :D
golfournut
Urea is a blend of Ammonia and Nitrogen and water. It does the same thing as a catalytic converter but updated. Supposed to be designed for the diesel market and not gas. When it is heated in the after exhaust pipe it brings the exhaust up 700 -800 degrees to burn the carbon emissions (CO2) out of the exhaust. I am not quite sure of the degrees I think it's more like 1000 degrees but it is hot. I sure wouldn't want to spill any gas on the pipes. Petroleum haulers are having a time with the new system because of the dangers of loading them on the racks with the hot pipes. I will bet there will be a huge fire sometime this year when they start upgrading equipment.
Wow that's hot. Does idling for extended periods increase the temp?
Your best bet, hire a vet! Please.
Stone Expeditors LLC
(941) 286-2558
Advertiser
Immediate Opening for Team Expedite Straight Truck
The best fleet in trucking is seeking a couple STRONG TEAMS to fill the seats of our new straight trucks with large luxury custom bolt sleepers and all the amenities. The market is back, the money is rolling in, and the wheels just keep on turning! Direct deposit every Friday. No deductions, no micromanagement from fleet owners or managers. Flexibl ... Apply Today!
LisaLouHoo
Question please . What is a urea tank or def ??
Per eHow.com:
Urea Tanks for Diesel Engines
"Urea tanks will be mandatory on all diesel engines made in the United States starting in 2010.
Urea binds with the nitrogen oxide emitted by diesel engines, thus reducing diesel emissions responsible for smog and respiratory illnesses such as asthma.
According to a spokesperson from the Selective Catalytic Reduction Stakeholders Group, urea tanks reduce the nitrogen oxide produced by diesel engines by as much as 90 percent.
Use of a diesel particulate filter can further reduce emissions to almost 100 percent."
Per Fleetguard.com:
DEF (Diesel Exhaust Fluid)
"DEF is a urea-based chemical reactant designed specifically for use in SCR systems to reduce NOx emissions."
So DEF goes into the Urea Tank and makes the world a better place.
I hope that answers your question!
BillChaffey
I would be willing to place a wager that my 1999 F250 or 2002 E 350 does not have a catalytic converter. The primary reason I'm willing is when the 1999 went in for it's first inspection after it was new. The young man at the Inspection station is crawling around under the truck. His boss Say's "what are you doing" he replies "I'm looking for the Catalytic converter" The boss's replies "it's a Diesel it doesn't have one, give him his sticker"
Jack_Berry
Moderator Emeritus
Nissan NV. Seen them, didn't know if they were doing an extended version or not. NOT a cabover, look alot like sprinters on the outside. (basic shape) Inside is NICE, cooler in the center armrest and other little amenities that make it very tempting. Base model has an AUX input on the stereo for MP3 or Sat radio even! I hear base price is gonna make sprinters cringe. 25k new is what I'd heard. Something to look at, if not to replace a sprinter, then to replace a C/V.
there are 4 separate threads on the n nv in the trucking section. it is not a sprinter replacement. it is hardly a ford or gm replacement. yet.
Speedwagen
Yep Jack, the Nissan is not a replacement- nor is this coming Isuzu/ Utilimaster thing as I mentioned in my original post.
I love the early (2002-2006) Sprinter- I own two of them.
Be nice to have a powerful 4 cylinder turbo diesel and a manual trans though, like they offer in Europe...
IMHO, the only real, existing "close to duplicating" the Sprinter offering
that would have a remote chance of seeing the US would be Ford's REAL Transit (Euro Version), and Chrysler/ Fiat/ Iveco's Daily Cargo Van- both look nice.
Here's a pic of each:
Rich
purgoose10
No, the lower the RPM's the cooler it is but still is hot. It is supposed to be hot in order to burn the CO2 out. Class 8 trucks will be a problem till people get used to handling them. Matter of fact all trucks will be a problem.
I have a friend who hauls freight in his Sprinter in the UK. They have no emission devises on their trucks at all right now. It starts next year. His Sprinter averages 28 mpg over there. I think its an o5 model, not sure might be an 06,.
jrcarroll
Rich
Just a note: I have been told from the company that Iveco will not be brought to the US.:mad:
If given a choice I would take an Iveco over all the other vans/ trucks..
Right now the urea additive is $2.97 gal @ Pilot. Put $75 buck in fuel and another $20 in urea.
Urea can be found for free in discarded plastic jugs at most truck stops, rest areas and on-ramps. Better yet, make your own!
SprinterGuy
I did not see a picture of it, but it said debut in about a week. Reading the spec page it looks to be a Sprinter competitor with more loading area (700) cu ft. The only draw back I see is the urea tank along with fuel. That's the one reason I'm going back to the gas engine. Right now the urea additive is $2.97 gal @ Pilot. Put $75 buck in fuel and another $20 in urea. Other than it should have a good market base.
I don't know how it is for the Isuzu but in the Mercedes Benz Sprinter the Urea tank is about 5 gallons and should only need to be filled up every 10,000 miles or so...Not with every fill up. The system will tell you when you are running low and need to refill.
purgoose10
"That's bad".
That's not so bad.:cool:
(941) 286-2558
Advertiser
