21cExp
And like most others , you're probably full of bovine scatology about how much you make too.. I can prove mine !!
Well aren't you an antagonistic little guy...
And you're a moron. Mind your business
I have all WalMart stores programed on my Garmin. I delivered in Downers Grove early Sunday morning and did a search for WalMarts in the area. Every nearby WalMart that was listed showed NOP. I had never seen that before. I googled "WalMart NOP" and found out it means NO OVERNIGHT PARKING. Learn something new every day. I moved on.
Alumininum (picture frame type) easy mount with rivit. just hinge one side to open with a little locking mechanism. similar to the one s that hold hazmat signs but in a square form.I wonder if it would be possible to put together a sign holder for each side of the van, and to have multiple signs if you drive for more than one company. Of course none of these signs are permanent, but they could be made to contain all the information the sign has to have, including company logos. If you have freight onboard and you're stopped for a paper check (it's happened to me once, many years ago) having the proper signs on your van goes a long way in the right direction to make things a little easier.
