My high idle has me at 1200 RPM. I think that is a good idle speed.
We are seeking experienced and reliable Class A CDL Owner Operators to join our team for over-the-road (OTR) and regional dry van opportunities.If you’re an independent driver looking for consistent miles, competitive pay, and flexible routes, we want to partner with you!What We Offer:Weekly Miles – Around 2,500+ miles per weekCom ... Apply Today!
Another option for the Sprinter is the OEM, "high idle" switch. Something that is included in all semi trucks, where you can idle it up.
The Sprinter option takes it to a prset 850rpms. It is most common on ambulance conversions, and those using the truck for other commerical purposes.
I believe the pricing on it is about $850.00 amd needs a dealer install, because it alters the ECM program.
I have that option, but it aint nowhere close to 850 rpm's. When I frist got this one I took it back to the dealership to see if we could reset the high idle, preset at 2,000 rpm's. He checked the ECM and we could only set the seconds it takes to reach 2,000 rpm. Later on in the week he called me. He said he call his help line on this, and was told the reason it is set at 2,000 rpm is due to the oil pressure needed to be high to correctly lube everything.
I also have the heater Aux coolant option, which is like the Espar but for the coolant. It will go into maint. mode when coolant temps reach 167 to 180, when it falls below this it kicks in.
I am not doubting what the tech told you, but 2000 rpm's that pretty high. I don't even have a cruising rpm that high heck I don't even accelerate that hard. 1/4 throttle is all she needs!! I would suspect any one driving for economy would not be having there engine spin that fast.
Yeah it is high....but is a known fact in the sprinter network...the engine is really racing...
What is your cruising rpm @ 60mph. Mine is 1830rpm. I am just curious.
For the T1N Sprinters (06 and earlier), the ECM high idle can be set between 1999 and 2000 rpm. That's yer choices.
At 2000 idle, it sounds like you're in a biplane or something.
No, it doesn't. Cruise Control isn't supposed to work at speeds of less than 25 MPH (40 km/h) as per the NHTSA safety guidelines (some vehicles still have the 35 MPH minimum). It has to do with how the cruise works, and is dependent on the transmission's speed sensor and other factors. Why yours engages at all while in neutral, I have no idea. Maybe it's a feature. You know, a feature.When I want to idle at higher RPMs, I turn on the cruise control, then tap the 'increase speed' toggle 7 or 8 times - does that not work on a Sprinter?![]()
Turtle for some reason in big trucks that is how you set the idle. In all 3 of my Class 8 Freightliner's I drove that is how you did it. Flip the cruise toggle on and then bump the set/resume toggle till it got to your desired rpm.
Company OTR Driver Average $1,650 - $1,800 Gross Per WeekPay & Compensation:Base Pay: $0.55 - $0.60 per mile (CPM)Average Weekly Miles: 3,000 milesPaid AccessorialsPaid OrientationDriver Benefits:Triad Health, BCBS Dental and Vision Insurance (starting after 30 days)Complimentary Life Insurance401(k) Plan with 4% company m ... Apply Today!
