The following are updated maintenance costs for a 2015 Ford Transit T-350, 3.5 Ecoboost, long and tall. These costs are for maintaining this Transit as it came from the factory and do not include extras like Espar, house batteries etc. Minor repairs and oil changes done by myself. Major repairs done at Ford Dealerships.
Oil Changes: 77 oil/filter changes, synthetic blend oil. $2,228
Air Filter: 273,731 miles. 7 @ $171
Headlights: Upgraded OEM halogen low and high beam headlights to Opt7 LED. 4 @ $260
Tires: 82,500 miles. Replace OEM Hankook 235/65 R16 with Michelin Defender 245/75 R16 4 @ $921
220,181 miles. Replaced Michelin Defenders with 4 new Michelin Defender 245/75 R16 @ $943
367,950 miles. Replaced Michelin Defenders with 4 new Michelin Agilis LTX 245/75 R16 @ $926
Wiper Blades: 451,047 miles. 12 @ $202
Giubo: 308,696 miles. Replaced flex disc (giubo) with Ford's not so final fix. $0
367,982 miles. Replaced Ford's not so final flex disc fix with Ford's final, final flex disc fix; an actual U-joint!
Transmission Flush: 308,696 miles. 4 @ $892
(service performed approximately every 100,000 miles)
Transmission Lead Frame: 414,995 miles. Parts and labor $,3298
Spark Plugs, Serpentine Belts: 4 @ 414,995 miles. Parts and labor $3,812
6 spark plugs, 6 coil boots and 2 belts replaced approximately every 100,000 miles.
#6 Spark Plug and Coil: 443,316 miles. Replace spark plug and coil. Parts and labor $450
Fuel Injectors and Manifold Assembly: 451,047 miles. Replace all 6 fuel injectors and manifold assembly.
Parts and labor $3,238
Throttle Body: 3 @ 459,701 miles. Parts and labor $1,421
Windshield: 1 @166,229 miles. 1 @ 348,026. Total $1,100. After carrier reimbursement, total $600
Rear Brakes, Pads, Rotors: 167,492 miles. Parts and labor $673
272,090 miles. Parts and labor $778
......................................................... $1451
Rear Brake Pads: @ 401,682 Parts and labor $170
Front Brakes, Pads, Rotors and Wheel Bearings: 330,759. Parts and labor $1415 @401,682
Differential Gasket and Lube Change: 414,995 miles. 4 @ $716
Induction Clean: 179,641 miles. Parts and labor $363
Replace Oxygen Sensor: 2 @ 220,206 miles. Parts and labor $730
1 @ 372,083 miles. Parts and labor $821. Price includes reprogramming CPM.
1 @ 381,418 miles. Parts and labor $430
Alternator: Alternator, serpentine belt @ 408,915 miles. Parts and labor $1,431
Shocks: 401,682 miles. Parts and labor $629
Struts: 401,682 miles. Parts and labor $1,391
Driver's Door Electrical Harness: 417,746 miles $768
Coolant Flush: 2 @ 414,995 $289
Starting Batteries: 431,224 miles. Replace original 2 starting batteries. Parts and labor $496
Misc: $195
*Driver Door: Replaced and body work: $1312, not included in maintenance costs.
Totals:
$30,692
478,364 miles.
.064/mile.
Own: 2015 T-350 long and tall cargo van, 3.5L EB, 3.31 rears, Espar B-4 heater, 245/75 R16 Michelin Agilis LTX . Used in nation wide expedited freight delivery.
This is my last maintenance post. I officially retired 12/31/2022. I plan on selling my Transit sometime in May. The maintenance costs jumped this year due to two expensive repairs, transmission lead frame and replacing all 6 fuel injectors. Had I decided to keep running into 2023 the cost per mile may have dropped some barring any other major repairs.
I hope this was helpful and gives a basis for what one could expect for maintenance and costs. I ended my maintenance records with a total of 478,364 miles.
Misc: $195
Totals:
$30,692
478,364 miles.
.064/mile.
