If your truck is still under warranty, they can NOT charge you to come jump start it, regardless if it's plugged in or not. I called HINO to come jump start my trucks several times
last winter when my guys 'forgot' to plug them in when they were either home or in a motel. Never got charged once. You might want to look into that more if someone is trying to charge you for a service that's covered under warranty. Sounds to me like someone is trying to rip you off.
OK so let me get this straight.... if you don't plug in your truck, it don't start?
This past February, in -30 degree cold weather, I had to shut my truck down. It sat for a day and a half in the open lot with the wind whipping up to 20 mph. I got into the truck when I got back to it, turned the key, let it go through its ecm checks and started it up. It started, stumbled for a moment and then ran smooth. It wasn't plugged in and this was a week after I had frozen fuel lines.
So what am I missing?
I do plan on using the additives, I wonder if the newer trucks are harder to start due to the reformulated diesel and that most is mixed with biodiesel, or maybe the fuel systems on these trucks are just more fickel No matter how long you crank some of these newer trucks they just won't fire when very cold unless you have the block heater plugged in.These HINO's tend to be cold blooded. When the temp gets down to 20 or lower, they tend to have a hard time starting if they're not plugged in or in a warm garage. It does help tremendously to keep the diesel fuel additives in the fuel. For some reason, this helps the trucks to start easier when it's real cold out. I keep a case of it in all my trucks in the winter & tell my drivers to add some whenever they get fuel during the cold winter months. It helps to keep those lines from freezing. We've also put some insulation around the fuel lines for the winter and haven't had a frozen fuel line since. Take it off in the spring. Might not look the prettiest but it works great and is much easier & cheaper than to have frozen fuel lines.
I would think my truck is out of warranty at 188K, not sure though, remember I do not own this truck I lease it.
I would be looking at possible other problems,,,no way should a diesel be affect by 20 degree weather,,,Have ya checked cranking speed,,,thought of possibly injectors leaking down during shutdown,,,wrong weight oil???
Its needs to be colder then He_ _ for a modern engine with clean fuel not to fire up as most have pre heaters anyways(I think)...Well below 20 degrees,,, if everything is in working order...Just my 2 cents..
Great suggestion but unfortunately I've found that even my brand new HINO's have the same starting problem when it gets real cold out. It seems to be one of the 'bugs' that toyota needs to get out and make better.
. I changed them out & put marine batteries in all the trucks. .
Can you please let me know the brand serial # Ext. ?
what will you recommended ?
in looking to upgrade to 950 ~ 1250 range cranking Amp's .
that will still fit in the box .
(BTW Inshasha... ,thanks for you post last week , i called the Hino , and it's show in the Comp. that the recall was done on my truck before i bought it , thanks.)
