Why am I overheating and losing coolant?
TMFGO45
It's in the shop. I will be updating when I know something.
Sent from my DROIDX using Tapatalk
nightcreacher
if water coming out exhaust,should smell antifreeze,look for white resedue at tail pipe
sounds like cracked head or blown head gasket though.I had smae problem,was cracked head.9 k to fix,sold truck
Try Hours Inc.
Try Hours Inc.
(888) 957-0400
Advertiser
$1500 Sign On Bonus for Tractor O/Os
Make $2200-$2800 per week driving solo for try hours’ regional tractor fleet. Owner operators will receive a $1500 sign on bonus. The region will cover MI, WI, IL, IN, OH, KY, W-PA and N-TN. Drivers will be home a couple nights per week and most weekends, with opportunities to make extra cash on the weekends.Immediate openingsList of bene ... Apply Today!
I have noticed a lot of Lot Lizzards get in and out of trucks, maybe they know how to fix overheating problems.:rolleyes:
TMFGO45
9 grand to fix the head? I'm getting my head tested, just in case, and I called parts to check pricing, and it's 2200 for the part. I was already paying the labor for the head gasket. For 9 grand, on this truck, I can pretty much get a complete in frame overhaul done (and more).
What truck did you have for that?
Anyway, they got back to me. It's the gasket, maybe the head, as I said, I'm getting that tested just in case.
I will update further as I know more.
ttruck
if you have a temperature gun, just point it at the radiator. That will tell you if that is the problem. I would follow with a pressure test on the cooling system. As for oil testing, forget speedco. Had this problem with a bad injector and oil smelled like diesel. Two different tests at different speedco's said oil was fine. Sent a sample to a lab and it confirmed our suspicions.
Speedco oil analysis are worthless based on our results.
"the definition of insanity is doing the same thing over and over and expecting different results".
are these temp guns sold locally
ttruck
you can get a new 335 cat motor from yancey in atlanta for 9000 plus install
TMFGO45
Okay everyone. It's been almost a month, but my truck is now fully repaired. What was it?
Testing confirmed a blown head gasket, further testing on the head confirmed blown head. Also had issues with piston cylinders, so an inframe overhaul was needed. Upon main barring install, discovered I needed a new block. While checking things out, it made sense for a new clutch. After all was together, test drive revealed it was still running hot. Because I now needed a new radiator.
So, after all of that, and $19000 later, I have a new truck, that is almost completely warrantied by fixes I've paid for.
Lesson to learn here? Keep your stinking radiators cleaned out, because it all starts there.
We bought this truck used, with no idea of the maintenance from the previous owner. He clearly either knew to dump it, or got lucky and hardly maintained anything. Either way, this truck is now almost all knew, warranty for a year, and ready to make some serious money.
So we are back on the road again.
And the brother truckers lived happily ever after.
The End.
Sorry for the expenses and hassles. Thanks for the update, tho. :)
paullud
Changing the radiator can be a little pricey but I think it is really important to protect all the other parts you just invested in. I hate when things like this happen to O/O's but I guess it is a risk of the profession.
chasem
You said it is not in your oil, did you have it sampled?? it takes alot of water/coolant to change dirty diesel oil. I would have it sampled ASAP!! If it is not on the ground and not in the oil the only other places it could be is the cab (leaking heater core or lines for it) or going out of the exhaust. Do you get a puff of white smoke when you fire it up?? or when driving it. You said 2 gallons low all the time, how often is that? every day, every 100 miles, or 500 miles.
Mine just got a water pump it was weeping only after sitting a couple of hours off. I would check the pump when I stopped for fuel or at a customer and the darn thing was dry :rolleyes: If I let it sit for about 6-8 hours there would be a small puddle on the ground and I was topping off 8-10oz every morning. I had my oil pulled as I have a gear drive pump and wanted to make sure it was not leaking into the engine oil, it was not thankfully.
I am sure others will give you some advice as to what it could be.
Remain safe and profitable every mile!
Idk if you’re still on here but yes when I start it, puff of white smoke then no more smoke the rest of the day. Losing quite a bit of coolant. None on the ground. Any ideas?
Try Hours Inc.
Try Hours Inc.
(888) 957-0400
Advertiser
