the funny part dave is you thinking that unless the name on the side of the truck is panther or fed ex then it must be impossible to gross over 200 with a straight. 30k per month I think that's doable with a team as far as gross numbers go running freight from 1.50-3.00 should be simple enough.
Ummm....no I wouldn't say that. I would probably throw Landstar in there as well for a single leased operator. I would say you can get to those numbers if you broker your own loads, but of course that carries much more costs and madness to operate. Ask me how I know. Part of the reason that I am leased to Panther.
I will give you a pass since you don't realize I have brokered alot of freight over the years. Including loads to members here at EO.
But outside of that, I look for consistency in revenue. Any one can find a good load on occassion. The reality is a leased operator at a small carrier isn't likely to hit 200k with frequency. Just a reality. If they did....well you guessed it, they wouldn't be small any more. Some will talk a good game, but the actual reality is in the numbers.
200k is possible, but outside of those carriers....a rarity. 300k isn't going to happen in a straight. Even a reefer/straight doesn't typically pull that kind of revenue and they have access to loads that a small carrier doesn't even qualify for.
But I guess it is ok for some to dream.
