If you have gps, set it to the city that is the center of the virtual terminal. When gps says you are within 60 miles of the city center of the virtual terminal, you will be in that terminal's radius. Don't need access to the maps to make that work. There are some vt's that overlap each other but only barely. Good luck.
I have seen no reason to be within x miles from a vt. Just go to the normal freight areas. Distance to a load seems to make a much bigger difference than distance to a vt these days
