No engine uses zero oil between oil changes, be it 10,000 miles or 3,000 miles.570,000 on my 06 chevy 4.8...still uses 0 oil between (10,000mi.)
You're welcome. Someone needed to. I'm simply telling you the physics and engineering of an internal combustion engine. Just because you haven't added the anywhere from one to five ounces of make-up oil the engine used doesn't mean that oil wasn't used. Zero is a very specific number, and it's one that is physically impossible to have, unless you never run the engine.
The only other way it makes sense is if the companies pay significantly more money if you have the heavier engine. They don't. I lost money on the Sprinter because the company I drove for dramatically lowered the rates while I was there. The company I'm with now pays the same per-mile rate whether I drive a huge Sprinter or a standard CV, so there's not sufficient reason to buy another Sprinter-- much less a diesel CV. Diesels cost more to buy and more to repair and maintain. The pay is the same whether it's gas or diesel. Your choice.
It is a cost. If you had a gasser like I do, you could just buy gasoline at BP like I do. Their gas comes with Invigorate. With Invigorate coming straight from the pump I don't need no stinkin' additives. Invigorate has changed my life. Since using Invigorate I think my hair has started growing on the top of my head. I have noticed an extra little spring in my step, although my knees still make a grinding noise. I have also noticed an increase in blood flow to some body extremities. Can you make the same claims using Howes or Power Service?You keep bringing up the cost of additives, as if that cost is a lot.
Is this for a Sprinter? What about labor costs?Some people replace their engines, some rebuild them. A rebuild kit is about $1800.
Then in the case of the E-350, why drop an extra four grand up front?I don't know that either one has a significant advantage over the other. It app depends on what you want and what you are comfortable with.
