Someone needs to test this.
Expeditors Online - Mythbusters Edition.
And this demonstration just cost me a 12 pack of Bud Light.
I just saw this done. Jeep is a 1968 with a 42 amp alternator.
an alternator will charge a battery easy depending on how many amp alternator, a friend of mine lives beside a tiny stream. he has an old bicycle wheel part way in the water with plastic balls cut in half bolted to the wheel. then the wheel connected to a one wire gm alternator,as the water spins the wheel it charges the batteries connected to the alternator
... a friend of mine lives beside a tiny stream. he has an old bicycle wheel part way in the water with plastic balls cut in half bolted to the wheel. then the wheel connected to a one wire gm alternator,as the water spins the wheel it charges the batteries connected to the alternator
That sounds cool!!! Brilliant!!!! Maybe a small version sticking out the van window for charging house batteries?!?!
I don't know a lot about what is said here but I do know that a car will run on the alternater with out a battery and will run with a bad alternater only until the battery dies. Therefore the alternater needs no other source of power but it's own to produce power.
I'll add, I built a small windmill using GM 1 wire alt. I have it hooked up to a deep cycle battery. This set up powers a bunch of LED lights I have in my shop. I also took a fan out of an old computer(most are 12 volts) and mounted it in my dog house for hot summer days. The lights are off in day and come on at dark. This setup as been running for about 3 years now.
