Seriously Mr. M, tell us about your experience. Year, mileage, any issues?
See.... you are about 15% of your mileageSeriously Mr. M, tell us about your experience. Year, mileage, any issues?
Here ya go...Lol...
2012 Nissan NV 2500 fully loaded. Current mileage 533900, Bought used in 2014 for $16000 with114000 miles logged.
4.0 liters 6 cylinders, average mpg 16-19, average speed 60-70 mph.
So far....replaced 1 alternater, 1 starter, 2 vent fan, 2 AC compressors, 1 drop and fill trans fluids change, oil changed monthly(about 10-15000 miles), 1 washable air filter, 3 alignments, 2 set of spark plugs replacement, 1 head lamp bulb, 2 serpentine belts, 1 brake pads set and replaced probably around 20 tires ( I buy used tires....Lol....)
The cargo area can take 2 skids. with 1 skid you can have a bed in the cargo area. With 2 skid, no bed but you can sleep in the engine compartment since it is soooo big ( Lol...).
I bought what I need for my work.
I carried mostly large containers. some are skid size and some are less than a skid size. Up to 6 pieces and sometime required stacking. Total weight ranges from 150-1500 lbs. Average 800 lbs.
Learned from the EO forum, most loads are 1 skid equivalent. Therefore, based on my type of loads, I decided not to pick the larger cargo van. My Nissan will do the job.
Thank you very much for allowing me to include the discussion of the Nissan NV in this forum. I'm no longer hurting.....Lol....Lol....
Here ya go...Lol...
So your total maintenance cost per mile is .05 CPM, correct? If so that is certainly a decent figure. My last Chevy maintenance cost was .033/mile for 820,000 miles. At 140,000 miles my 2015 Transit is running a hair over .02/mile but certain to climb.I guess I can't complain, really. So far @ 275,000 I have spent only .018 CPM on major repairs and less than .05 CPM on TOTAL maintenance & repair. However I have no clue if that is good or bad.
Thats what I said...even with the nag problems thrown into the equation...he has a decent %...So your total maintenance cost per mile is .05 CPM, correct? If so that is certainly a decent figure. My last Chevy maintenance cost was .033/mile for 820,000 miles. At 140,000 miles my 2015 Transit is running a hair over .02/mile but certain to climb.I guess I can't complain, really. So far @ 275,000 I have spent only .018 CPM on major repairs and less than .05 CPM on TOTAL maintenance & repair. However I have no clue if that is good or bad.
Are Canadian opinions worth more or less? I'm not sure on the current rate of exchange?PS I welcome your thoughts, opinions and criticisms, even Canadians.
Update please.I am not a gearhead (although I an quite good looking) but I am at a loss trying to understand what is wrong with my T350
At 2000 RPM I feel a shudder that goes away when next shift point hits. My first thought was Torque Converter (again?) which was replaced less than 50,000 miles ago. Now at 275,000.
Mechanic sort of ruled that out, for now, BUT when put on the scope ALL cylinders are misfiring all the time. Note that I have replaced coil packs & plugs twice already, which I do at every 100,000 mile service. Mechanic is scratching his head.
Any thoughts?
OK, $700+ later good as new. Are you ready........... several clips that hook on coil packs we're broken causing intermittent spark, sending signal to TCM to tell transmission to back down under torque, such as accelerating at higher speed. When they told me I was skeptical, but that's what it was. $140 part + $640 labor. Ouch, but better than I feared
Yes & changed belt @ 250000. Do oil every 7500 with full synthetic too.Do you change out the coil packs and spark plugs every 100,000 miles? How often do you change the serpentine belt?
