And then you have this as an example of how not to show your appreciation.
Cheltenham Veterans Cemetery, Maryland: Saturday, or Sunday of this week.
Hey everybody. I used to work for the VA cemetery in Portland Oregon. The Willamette National Cemetery. What you see is not necessarily uncommon. In the winter months, the rains make the ground very soft and you have to get the equipment back there no matter what. We used to lay out fiberglass matting to help prevent rutting and displacing headstones. In the event the matting was in low supply we used sheets of plywood. I'm not defending them completely since they could have been way more careful but if that cemetery is anything like the Willamette. They do care and will have it repaired as much as possible at the end of the day. Most of the VA cemeteries employ nothing but veterans so guess what, they're getting buried there too. You have to consider a few things. If they don't usually get horrible weather they may have not been as prepared as they should have been or maybe the irrigation system had a bad leak and they don't typically use matting cause the ground is usually hard enough. At the Willamette National Cemetery, we loved to screw around but in the end, we made sure the grounds were beautiful and not because we were told too. All I'm saying is, don't bag them unless you know what happened for sure. It can be repaired and usually is even if it comes to down to staying late to fix it.
You just might be onto something there ...All one needs to know..............
The size backhoe they would need to use would be dependent on the depth/width of the hole that they need to dig.They disturb the graves at the local city cemetery in town often enough, but repair the damage rather quickly. So, apparently it's not all that uncommon. Still, seems a little bizarre that they'd use such a huge backhoe for that. It all just seems odd. Then again I've never worked in a cemetery, so I dunno.
There are two clear vested interests at play:
1. The DOD's vested interest in an outcome which shows that what they put people thru (war) isn't at fault.
2. The vested interest of those conducting the study to produce an outcome that the DOD will be happy with and that will not stand as an impediment to them getting more paying contracts from the DOD.
Some observations from Laurence Vance on some of what constitutes our present national insanity:
I have read the above article about 3 times. Mr. Vance is a brilliant writer and is educated far and above the call of duty. But the uniform cult thing IMHO, he is wrong. It appears to me that someone must have pee'd in his bran flakes the day he wrote that article and he was all backed up inside. He was really on a tear there. But in America he has the right to express his opinion and that's good.
A few more comments: I have stood in church when military veterans were recognized. I have received discounts when buying a 3 dollar shirt at a thrift store--got a whole 30 cents off, my oh my, not for my military service, nope, I'm over 65. Lets see now, I was never told to go overseas and shoot someones mom, that was a low blow statement from Mr. Vance.
I have never witnessed a uniform cult turn an atheist into a religionists, or jews into evangelicals, or Christians into idolaters....yep Mr. Vance got all that incorrect, but it must have been that cereal thingy. Yes Mr. Vance writes well and some of his articles will make you think and that is a good thing, but again, the uniform,I always wore it with pride, amen.
Not sure that that's really all that clear. The DOD certainly has a vested interest in the study, but I don't see any clarity in the study to support such a conclusion of a particular vested interest in a particular outcome. The purpose of the analysis wasn't to reach some predetermined outcome, but rather to gather "valid and generalizable epidemiologic research from which to confidently ground clinical and policy decisions ... about the magnitude and causes of the problem and how best to approach it." It turns out some "common knowledge" assumptions may be incorrect. The assumption is that specific deployment-related characteristics, such as length of deployment, number of deployments or combat experiences are directly associated with increased suicide risk, but that turns out not to be the case. However, of those suicides with combat experience, they were also more likely to be combat specialists and have pre-2001 deployment experience. They study, while extensive, only uses data from 2001 up through 2008, and more recent data needs to be analyzed and compared, especially since eight years ago the military suicide rate mirrored that of the civilian population, and in those eight years the military suicide rate has increased. They need to compare that to the suicide rate of the general population over the same eight years. If the civilian population rate matches that of the military, then the increase is probably due to the recession, or Obama.You just might be onto something there ...
That almost sounds like you think the Naval Health Research Center is some outside, independent agency, and not a US military installation of the US Department of the Navy, under the Office of Naval Research, under the command of the Navy Bureau of Medicine and Surgery (BUMED), Falls Church, Va., the Naval Medical Research Command, Silver Spring, MD, and Navy Medicine Support Command, Jacksonville, FL.2. The vested interest of those conducting the study to produce an outcome that the DOD will be happy with and that will not stand as an impediment to them getting more paying contracts from the DOD.
Or the person who believes that everyone who puts on a military uniform doesn't deserve to be honored for it until proven otherwise just may be the fool. No, not everyone honors the uniform, but everyone deserves thanks and respect for wearing it until such point as they prove otherwise.
Keep goin' ... 'cause you still ain't there yet ...I have read the above article about 3 times.
Individual experiences may vary.Lets see now, I was never told to go overseas and shoot someones mom ...
Not really ... ROE's are what they are ...that was a low blow statement from Mr. Vance.
One's lack of ability to observe a phenomena is not proof that the phenomena doesn't exist in fact.I have never witnessed a uniform cult turn an atheist into a religionists, or jews into evangelicals, or Christians into idolaters ...
Your (likely inadvertent) use of "amen" is ... quite telling ...Yes Mr. Vance writes well and some of his articles will make you think and that is a good thing, but again, the uniform, I always wore it with pride, amen.
One doesn't have to examine the study to locate the vested interest - in fact, doing so may result in ignoring the very thing - the elephant in the room as it were - which provides the evidence of vested interest: the fundamental purpose of the DOD itself.Not sure that that's really all that clear. The DOD certainly has a vested interest in the study, but I don't see any clarity in the study to support such a conclusion of a particular vested interest in a particular outcome.
All governmental entities are subject to funding - in the case of the DOD, I'd wager that those further up the DOD food chain have some input and control over who and what gets funded, and to what degree ...That almost sounds like you think the Naval Health Research Center is some outside, independent agency, and not a US military installation of the US Department of the Navy, under the Office of Naval Research, under the command of the Navy Bureau of Medicine and Surgery (BUMED), Falls Church, Va., the Naval Medical Research Command, Silver Spring, MD, and Navy Medicine Support Command, Jacksonville, FL.
Funny that ...Read the first paragraph of the essay by William Deresiewicz [cited in the OP], cause he's describing you, and he's calling you a liberal, lol.
Indeed ...The point of the OP is that this particular group is becoming [or has already become] the object of unwavering knee jerk devotion and applause - and this particular group has the potential to be used as a weapon against the very people it is supposed to be protecting, so that is more worrisome.
Nevertheless, the vested interest in the study isn't all that clear, at least not to me. I can see several vested interests beyond just the one you listed, and the one you listed as being one of the minor ones, at that. The more weighted and critical vested interest would be, it seems to me, to find out the actual causes so they can be properly addressed so as to minimize the frequency of suicides. Doesn't seem like a study with artificially created or spurious results would be a benefit to anyone, especially the DoD, since they take the heat for every suicide, regardless of the cause. Seems to me they have a far greater interest in getting to the root of the problem.One doesn't have to examine the study to locate the vested interest - in fact, doing so may result in ignoring the very thing - the elephant in the room as it were - which provides the evidence of vested interest: the fundamental purpose of the DOD itself.
If we're going to call it something in any way correlating to reality, it should be called the Department of Aggression and Economic Interest Defense. But I digress.Once upon a time the DOD used to be accurately named: It was called The Department of War (also called The War Department)
It's something we should consider re-adopting ...
That's all true, but that in no way equates to "paying contracts from the DOD" in the same way an outside entity gets funded. The commanding officer and other military personnel assigned to the Naval Health Research Center couldn't care less about DOD contracts to fund the installation any more than those assigned to the USS Gerald R Ford are concerned about it. So paying contracts is very unlikely to be a motivation in the outcome of the study. That's all I'm saying.All governmental entities are subject to funding - in the case of the DOD, I'd wager that those further up the DOD food chain have some input and control over who and what gets funded, and to what degree ...
