bayouhotshot
i have been thinking of going to some super singles what yall think alote of guys say thay are geting better mpg with them and ware can you get them at?
....if you should have a blow out on the road.Hard to limp to a truck stop with a flat tire, and when the guy comes out to fix you,he's going to bring you out another 750 dollar tire .IMO just not worth it.
the mpg difference isn't worth the cost,if you should have a blow out on the road.Hard to limp to a truck stop with a flat tire, and when the guy comes out to fix you,he's going to bring you out another 750 dollar tire .IMO just not worth it.
If you are having blowouts often enough for this to matter you have bigger problems with how you treat your tires.
In fleets, whenever I used them I would see a solid 2/10ths MPG improvement, no matter the driver. At 100,000 miles a year at 6 MPG and today's $2.92/gal the savings are $1568 per year. That is just doing the tractor. Are you really going to have that many blowouts to eat up those savings?
Single tires run cooler, your brakes run cooler, and you save fuel. Sounds like a good idea to me.
can you buy snow chains for them
