Does the money part vs. comfort part have to be black and white? Would a more comfortable sleeper allow you to stay out longer? Would it cut down on motel expenses? I am just not convinced that it is either or.
There are a few shippers that will not load a Sprinter that does not have a solid sealed bulk headAs much as these conversions look sweet besides the 10K...they do not make you any money and probably lost loads that = lost revenue...hard to justify the investment over a 4-5 yr term..
If you strap your load down proper and heavy bulkhead is unnecessary....
Keep the focus...it is a WORK truck...while comfort is a consideration....your focus should be...Make Money...
Me thinks there is no right or wrong here...just difference of opinion...call it business strategy...
10 grand? Really? $10,000?
No 2 pieces were the same, every piece measured and cut to fit....a masterpiece!
My paramount consideration was to be able to sleep while loaded, no ifs, ands or buts. I spent far too long in a short wheelbase E-350 where 2 skids would be right up next to the back of the driver's seat. Too many Friday pickups for Monday delivery and no place whatsoever to sleep.Well there is two different approaches for some to consider..
1. Lifestyle first then income...build your van to your lifestyle..
2. Where I built mine as maximum income potential and built my van to that plan....
Yeah, same truck, different set of pictures. The opriginal pictures you was were hosted on a site that went belly up, so they aren't in the http://www.expeditersonline.com/forum/truck-talk/22494-trickin-das-sprinter-teil-zwei.html thread anymore. There is some good information in the text that remains, tho. But I've posted them here and there. Problem is, there's just too much on that guy to search for something that specific.I assumed that,, and see that.It is a nice job on that sprinter.
Those weren't the pictures I saw but same shelf & truck I think..and what I wanted to see..
Same set up I wanna go with, but only on one side for now.
It's pretty tight. Not tight tight, but close. It had to be close enough to get the right-angle brackets on the shelf support and the wall of the van. If you have someone to help you, which I didn't, you can fashion a large compass, like you used in geometry class, a big V thing, and use that to trace along the wall of the van and have a marker on one point to mark the wood that someone holds up next to the wall.So I gotta ask Turtle how did ya trace or copy the side of the upright boards that sits against the truck wall? (So the board would follow the contour of wall.) it is tight against wall correct?
Not really. Every now and then I'll get something that's on a 48" skid but it's hanging off the edges of the skid. That's as much of a problem with those little side walls than it is for the shelving. The narrowest part between the wheel wells where those sidewalls are is about 49.5 inches. So it can be a little tight. I've had 2 or 3 loads that were nearly too tight for the shelving, and it got rubbed a bit, and a couple of times where an over zealous forklift operator really hammered the most rearward shelf supports, but that's to be expected, and it really hasn't happened anywhere near as frequently as I thought it would. The rear doors open and the see all that shelving, and how tight the tolerance is on either end, and most are suddenly extremely careful.1 other Q,,have ya got in a situation where ya could not load due to width of freight.(shelf getting in the way)
If you want to make a template or guide to follow the wall contours here is how you can do it - would probably require an extra set of hands:So I gotta ask Turtle how did ya trace or copy the side of the upright boards that sits against the truck wall? (So the board would follow the contour of wall.)
Actually you could probably say it either way and it could still be considered accurate - kinda like the difference between markup, which is a percentage of the original amount, and gross profit, which is a percentage of the whole or final result.Just read this for the first time and I like it but you aren't 25 percent more likely to be shot in D.C. you are 33 percent more likely to be shot. 60/3 = 20. 60 + 20 = 80. That makes it 1/3 more likely not 1/4 more likely. Even more reason to pull out of D.C.
However, no matter which one used, I agree with the overall sentiments expressed![]()
