Ken,
Thanks for taking the time to go into greater detail - from me, coming into this game with no experience with freight securement, the advice that everyone has provided is invaluable.
>That looks like a short wheelbase Sprinter
Yup I think you're right.
>A 2K lbs WLL load bar is nice, but the walls of the van will give way long
>before the rating of the load bar gets tested.
Right - but given the choice, I'd rather be in that position than the other. $50 for a load bar is cheap insurance.
>Yes, you are.
Hey what can I tell ya ? ..... I think the black 'copters are circling overhead as I type right now. :+
>It's a 1/4" screw. Holes are exactly 2" apart, center to center, and the
>rows of holes are exactly 4 1/2" apart, center to center.
>The power of a few screws can add up quickly.
Right - I was only going off the picture you posted - perhaps it was taken before they were finished running all the screws - as it stood there were way too few screws for my taste.
>I do have a permanent bunk built in there, and it acts as a partial
>bulkhead, even if it's only 21 inches high ....... A Sprinter is still an
>unusual vehicle specially one like mine where the fridge and
>microwave towers above the bunk.
Do you have any pictures of your unit & living area posted up on line ?
>Corny, but hopefully that's a description that can be visualized.
Got it on the barrel/drum securement - it's actually a great description.
>you really don't want to use the sidewalls of a van as the primary
>load bearing contact point for anything heavy.
Yeah .... after looking at the construction and how thin the sheetmetal is that was pretty much my conclusion. I've bent up way too much steel to place alot of trust in anything that thin.
>One time I saw a Sprinter that had been carrying a single 750 lb barrel ......
Ah .... that was your post .... I read that while researching the boards here on EO. You questioned the load securement and the guy said not to worry .... he's "been doing it for years" .... scary ..........
>For a single barrel, however, I always lay a 2x4 across the top ....
Got it - basically the length of the 2x4 is at least as wide, maybe a little wider, as your E-Track is spaced on the floor.
>Anything under 500 pounds and the wall should be fine
Right.
>It's a never-ending process, too.
Of that I'm sure.
>After having said all this, it's way better to over-do it than under-do it.
>Better to be safe than stoopid. ...... You'll be thankful that you were a
>little paranoid ......
That was my take on it .... I'd rather be paranoid and safe ..... than a fool and hurt ... or worse yet ..... dead.
>..... and this is how I do it, you can do it however you want ....
>...... Sorry for rambling. .....
Not at all - that's a great viewpoint on professionalism, and like I said before the advice on freight securement is invaluable.
>Yes, you are.
Right.
Of that I'm sure.
