September Locations
Falligator
It's a new van too! I know I need to get rollin soon but definitely nickel and diming here! I think I got the check engine light curse. Was told there is an issue with the turbo sensor saying that it was overheating
asjssl
I have an app for my droid called Torque...it requires a $20.00 gizmo that plugs into your OBD2 port...its bluetooth..it reads your vehicles computer..you can read and clear codes...AND you can can set up digital gauages on your phone for just about any fuction of the vehicles engine...temp..volts...tach..turboboost..pyrometer...etc...so when that check engine light comes on you can read it and clear if need be.....
Sent from my DROID RAZR using EO Forums
FlyingVan
The problem is that it only reads emissions codes that are mandated by the government. It will not be useful for any codes in the 15 or so other computers in a sprinter. It can be somewhat useful for the gauges, just like a scangauge, but it is not reliable for code readings.
Sent from my PC36100 using EO Forums
asjssl
It will read any code the computer throws...do you have one??? It is very reliable been using it for awhile...
ohiomike08
Laredo is horrible right now! Full of expediters and no freight! Even semi drivers are not moving...heard not a lot of freight coming across border. Hoping that changes soon!
Pagan Trucker Girl - Blessed Be
Been here since Saturday morning. Only thing moving north is freight on the Union Pacific railroad.
FlyingVan
Do you have a Sprinter??? I guess not, cause you wouldn't argue with me if you did.
asjssl
Gees who peed in your corn flakes know it all...it will read any code for a OBD 2 ...would NEVER own a sprinter anyway..dont need those headaches...
FlyingVan
As,
Nobody peed anywhere. Do I know it all? Far from it, but I know a thing or 2 about sprinters.
But my post was for falligator, so he will not buy what you suggest
thinking he will be able to read all the codes, cause he won't.
asjssl
As,
If it has obd2 it CAN read all the codes...do you have this app??
FlyingVan
Yes, all cars/vans after 1996 have obd2, and no, it will not read all sprinter codes.
The more you argue, the more you show your ignorance on the subject. Like I said, it was a heads up for falligator. I don't have the desire to go back and forth with you, so you can argue by yourself.
asjssl
As,
How would you know if you dont have the app?? Its 1997 anyway...
I am Smart enough to NOT own a sprinter..
spongebox
Eight days in laredo, I'm about to have my mail forwarded here cause it seems I'm now a resident,
Sent from my VS910 4G using EO Forums
FlyingVan
Man, I hope you won't break tjp's record. I think it was somewhere around 3 weeks down there.
Falligator
So I'm finally done with Stoops and they found some sensor that was supposed to open and close was staying open. Headed to yard to get decaling tomorrow.
21cExp
At the house tonight, with a load going from Louisville > Wayne MI to pick up in the morning.
Sure has been some sweet weather across the middle of America the last few days. Almost makes me not care if I was loaded or not. . .
jimby82
Picking up north of Detroit in a bit, to Philly in the morning. Then a short run from PA to NJ. Probably head to Bordentown, unless of course, we get a load out ;)
