Say Hi to July
fastman_1
Plane took a wrong turn somewhere won't be here till 8:30ish.... And I now hate airfreight!
Loaded late last night Columbus Indiana to Lincoln Alabama... Reloaded in Tuscaloosa going to grand rapids Michigan....
fastman_1
Hmmm let's see here, there's a try hours straight truck and a nitro express van and some courier cube truck and me, all waiting on the same plane to land, wonder who is getting screwed out of their load??
FlyingVan
What size of converter is the largest I could get without messing up my battery
lesbianlover
The answer depends on the type of battery. If you are talking about the starter battery, then the answer is none, unless you want to use it only when the van is running.
f4ftrucker
Ok then what do you suggest. I wanna get a mini fridge and tv in my van. I don't know what size battery it has right now cause I will be getting it back next week.
And I'm tired of not being able to pack cold foods and spending money all the time.
lesbianlover
FlyingVan
lesbianlover
You need to install another deep cycle battery/batteries to be able to do what you want. If you run that fridge off of the starting battery, you will kill it. The starting battery is designed for a different kind of job.
Sent from my SM-G900P using EO Forums mobile app
fastman_1
Looks like the courier cube was the big loser, his load was to big for the plane, so his was on a second plane 2 hours later.
lesbianlover
You want a minimum of a single 12 volt or dual 6volt. Either way the preffered battery would be a deep cycle agm type. More expensive upfront but cheaper in the long run. You also need proper heavy gauge wiring and a seperator.to keep from drawing the cranking battery down when running the aux.
Done right with minimum batteries your probably looking at 500.00 to 1000.00 dollars.
Oh get the right inverter too if you plan on running a laptop or other sensitive electronics. A friend just found an 1800 watt tripp lite on ebay for 239.00 free shipping.
Sent from my Fisher Price - ABC123
xmudman
Jeannette, Pa to Cincinnati.
Now at J in Walton, Ky.
Sent from my XT1028 using EO Forums mobile app
Yesterday, had time to say a quick hey to Xiggi, then did an Avon, In back to Cincy. Today, Cincy to Athens, Tn. Tomorrow, a run to Tejas :) . God is hearing my prayers :cool:
in-Transit
Delivered to San Antonio this morning then immediately went to a hotel... Yep was a ruff run LOL
