This will probably be a minute amount of saving, but every little bit helps. While driving with cruise control on, every time you want to kill the cruise you must tap the brakes. When you tap the brakes that probably scrubs off a minute amount of brake pad surface. To eliminate this, wire up a push button switch that you can press to activate the brake lights and it will also kill the cruise. Does any auto mechanic agree/disagree with the wiring? I have never done this but it seems like it will work.
Thanks. :+ :+
