David,
Nice ride!! I really like the flat floor above wheel wells, makes for a lot of extra cargo space.
Is that a single wheel rear axle under 10K GRVW or duel rears with a 12K rating?
Did you go Gas or diesel?
I might suggest you insulate the overhead in the cab, it will make it a lot quieter and COOLER.
Excellent job!!
Thanks for the tip on the overhead.
So far the cut out roof hasn't seemed too hot yet. It looks like it will hit 90 today here at Rock Hill, SC. I'll jump in later and feel the roof.
I went with a 6.0L. The Duramax is a great engine, but it adds 700lbs more to the GVW. I traded extra living room for reduced cargo weight and the Duramax would have turned me into an RV and not qualified to haul the minimum required.
It is a Dual Rear Wheel at 10,000lbs GVWR.
Believe me, it was a difficult chassis to locate.
One thing for sure, it rides so much smoother than my regular SRW cargo van built on the same platform. The wheelbase on the new truck is also 4 inches longer so that has a positive effect on the comfort level as well.
Thanks for your advice!
