westmicher
But yet you think the Transit will be OK in the first year. .
Sent from my SGH-T959 using EO Forums mobile app
Who knows? I'm going to put an aluminum 16' box on the cab/chassis and see though.
Actually the 9350 gross weight would mean little with the 4900# cargo limit.
I'm thinking those front axles and U-joints better be top grade and super strong though. That's the weak link in front wheel drive, especially in a tough service situation. I wouldn't buy the first year of this one.
I don't like the side slider(s) though, on either ProMaster or Transit, and much prefer the barn door style.
I'm wondering about the GVWs too. Why only 9350# in the LWB High Roof Ext?
I'm curious about why you don't like the sliders. Also, who is going to worry about that last 650 lbs that much? The fact is, the van is definitely going to carry more under 10K than the competitors. I seriously doubt i'd worry about exceeding 9350 lbs now and then by a little.
They say that properly loaded, it's about 50/50 weight distribution while loaded.
My experience and personal preference is just the opposite, at least with GM vans. I have had both swing and sliders. The hinges on the side swing doors tend to bind up after a few years due to poor design. One can drill a hole in each hinge and insert a Zerk allowing the hinge to be greased. 9 years on my slider and no problems.Re: Sliding side doors - Mostly just personal preference after having vans with sliders and barn door style. As they age, the barn doors are easier to deal with, less maintenance in my experience, and I like being able to only open one half instead of having the entire top and bottom edges opened to weather and wind when using a sliding door, even if opening just a fraction. It's just a personal preference, really, based on personal experience with both.
Isn't the first year of this Ram van a few years ago when Fiat brought it out? Is it really the same for old established models being rebadged and brought to a different country? I don't really like carrying more than 1 ton in a 1 ton van. My van could carry 2893 without exceeding the gvw on the door plate. I set my limit on my contract at 2500, the minimum required amount for the carrier. That said, I still think they should have built it to 9990 not 9500 gvw. There's always going to be knuckleheads who think it's fine to run at 9958# on a 9500# chassis because it's still below 10k and it's not that far over. If they'd made it 9990# they have at least saved a few idiots from themselves.
Need to remember these things aren't really built with expediters in mind. We are just a niche.
