ProHeat question
I went out to my truck the other morning to check on things. The APU had come on itself to charge the batteries. It sounded BAD. It was blowing a LOT of blue smoke. I shut it down right away. I checked the oil, OK. Both belts were fine, just had both of them replaced two weeks ago.
I let it sit for about 10 minutes and tried to restart it. It fired right up and ran perfect. Been running fine ever since.
Anyone have any ideas?
I am lost on this one.
ts675
I am not familiar with that apu, however if it is operated on a glow plug system that could be bad, if it has some type of electric choke I would look there, irregardless that would be where I would start. Hope that gives you at least an idea where to start.
It is a two cylinder Izuzu IF I remember correctly. Two cylinder for sure. I did NOT buy the truck new, had no book on the APU and Carrier could not get me one. :(
Glow plugs could be the issue or the wiring going to it. Other possibility is the electric fuel pump is hanging up. That is assuming that it has a good air filter on it. Manuals can be downloaded from the Carrier site.
Dynamite 1
might have been as simple as a stuck ring keep an eye on it and use it like normal. i think the engine in the pro heat is either koehler or kubota.
All filters/belts are only two weeks old. I will check the site. I could not find the books before, Scott's has not been able to find it either. I have NO idea as to why.
geo
give bill moore at tsi a call they are western star dealer
in north jackson oh off of i76 they are best for working on proheat
purgoose10
The last APU I had, every once in a while it would loose fuel pressure after sitting. It did the same thing but always straightened itself out.
Mine also had a hand pump by the fuel filter. Don't know if yours is like that, but if it struggles to start just pump it a couple of times and it will kick right off.
