Decided to edit and count to ten.
Just look at what's been said. It's not primarily about cheap freight, since we all know than not every load will be a home run. The issue is the failure to communicate anything unusual about a load when the load is given and accepted. "Unusual" being, among other things, an abnormally low rate or a delivery time that is not either straight through or when the consignee opens up the next morning.
The vast majority of our loads pay a certain ballpark rate, or higher. Anything substantially less than that normal standard qualifies as unusual.
The vast majority of our loads deliver straight through, or ASAP when the cons opens up the next morning. Anything that delivers substantially further out than that time frame qualifies as unusual.
Another one of my favorites is, there is a difference between picking up a load in Romulus and one picking up at the airport, even though the airport is located in Romulus. If the load picks up at air cargo at the airport, then dispatch should say "air cargo at the airport", not "Romulus". Same with "Hartsfield-Jackson" versus the more generic "Atlanta", or "Logan Airport" versus "Boston". Pick any city and and airport you like. There are plenty of loads picking up in a given city that requires little consideration in making a decision, but one picking up at air cargo is something else entirely. One could be a quick and easy two-hour run, the other could be a six-hour ordeal.
A load paying 83 cents a mile that picks up on Friday and delivers on Saturday is a lower-paying load than normal, but like you said, that's part of that two-way street that averages out. However, the same load that picks up on Friday but doesn't deliver to Monday becomes a substantially less paying load considering the time involved in committing the truck to that load. It's certainly a consideration that needs to be factored in, and it's one that cannot be factored in unless we know about it before the fact, rather than after we've committed to the load.
We certainly could spend a lot of time playing 20 Questions trying to discover anything unusual about the load, but it seems far more efficient for dispatch to just tell us up front about anything unusual or out of the ordinary about the load so that we know what we are getting ourselves into from the beginning. Otherwise, we feel like we've been suckered a little bit.
If I were offered a load paying 83 cents a mile that picked up on Friday and delivered on Monday, I'd probably take it (and even more probable if it delivered direct, or the next day). The load's gotta get covered, I don't want to put dispatch in the position of having to call the customer and back out of the load, the higher paying loads and the Layover Pay certainly makes up for many of the lower paying loads on the average on this two way street, so I don't have a problem with a load like that. But it would be a decision that I'd make knowing full well what I was in for, rather than a decision made based on engendered trust that burned me. It's very difficult to make an informed decision without the information necessary to make it.
