Need help with rear end issue.
Filling a Chevy to overflow does not fill it after overhauling. You have to turn the wheels several times and get the fluid out to the axles then top it off. It's best to run it around the block come back then top it off. A lot of gearing gets lost when people don't do that.
I got to ask, how does turning the wheels move the fluid from the center to the axles when the fluid level isn't high enough?
Dakota
Well there isn't anything to put into the rear end to make it quiet except sawdust. Any claim to make a rear end quiet is about the same as Obama being a libertarian.
Cutting beans out of your diet will cut down on rearend noise:D
Ascent Expedite
Ascent Expedite
414-615-1556
Advertiser
Peterbilt Lease Purchase
Our Class A CDL Teams Earn Up to $40000.00 per MonthLate model Petes - Cummins or Paccar, Automatic, APU, low miles Paid Fuel SurchargeEarn up to $2.00+ per mileAll Miles PaidPaid Assessorial• MUST HAVE 2 YEARs CDL A DRIVING EXPERIENCE• VALID CLASS A CDL• DOT MEDICAL CARD• PASS A DRUG TEST – ... Apply Today!
nightcreacher
Sawdust is a good trick if you are getting rid of your ride.Lucus is the biggest waist of money you can spend on your truck.If the rear end had synthetic gear lube,and you replaced it with regular oil,that could cause a hum.Watch you rear end temp,bad bearing will cause a hum,and rear end to over heat.If you had the ring and pinion gear out,that could be the noise if you didnt get it lined up right when replacing it.Good luck
purgoose10
I ment to say if it's on a rack put it in drive and run it. It will circulate with the gear spinning. Hopefully it's not that low.
