I'll pick one up on Friday. Anyone have step by step instructions on how to install it?
With-out knowing where yours is mounted but since you been heating it up all week you should have a good idea where it is..
Usually 2 mounting bolts and several air lines going to it..Drain air system..Note location of all air lines and disconnect em..New Gov will have new brass fittings,install them in the same locations as the old ones,,plug any open holes with plugs provided in new kit. Attach air lines..Mount gov to its original position. Sometimes it may be better to put some of the air lines on last depending on mounting location.. If mounted on top of air compressor there should also be a small gasket involed..Clean mounting surface then bolt new one in place..
Tools required should be 2,,7/16 wrenches and an set of allen wrenches for the gov itself. ..I forget what size wrenches for the airlines. 1/2 or 9/16 ???
Just look it over and if you feel comfortably doing it get er done and save some money. If all else fails the Shop @ the TA should get her done in under 1 hour.
(Oh yeah...Dont forget your safety glasses and to crib your tires
