Even though 0W-40 is the recommended, I was told by a Mercedes tech in Chicago that I might want to run 5W-40 in a higher mileage Sprinter. Anyone see a problem with that? That's what I've been doing for about 200,000 miles with good results.
Don't want to use Lucas in a Sprinter, either.
People sometimes don't believe me when I tell them everything they know about engines and maintenance can be tossed out the window when it comes to a Sprinter. You have to learn all the rules again from scratch. The only rules that apply are Mercedes Rules.
Im thinking of going with Amsoil oil when my warranty runs out. Any thoughts
As long as you can meet MB standards for your model, it shouldn't be a problem.
update: Just ran across a discussion elsewhere about Amsoil and the MB spec. Apparently there are a couple Amsoil oils that carry the MB spec, but Amsoil will not have the oil tested for MB to put it on their list. So, do you feel lucky?
eb
What do you suppose the bad results might be? Would you recognize them if they were there? Is three percent additional wear likely to be noticed? I dunno.
In the same way that not all 10W-30 oils are not the same, neither are all 5W-40s the same. As long as the 5W-40 you're using is on The List, there should be no problem.
Not sure what you mean by three percent additional wear, Turtle. What are you referring to? Incidentally, I'm using the Mobil 1 5W-40.
Hey EB, enjoy reading what you have to say about sprinters. Ive been told that Amsoil is a great or the best oil for a engine cause its like a deturgent, I know I spell that wrong,lol. It keeps your engine very clean and can go longer on oil changes cause it doesnt break down as quick as others do. I dont know if I feel lucky, lol. Mine is a 2012 MB Sprinter. Only 20,000 miles on it, so ive got awhile. What do you think?
