Wow.....I just like tidy!
Then don't look at the pictures of my mess. The batteries are in black plastic battery boxes with tops and are located under my bunk.
I know just enough about a lot of things to make me dangerous, including expediting. Especially expediting!Moot, I'm dead serious about helping do a rewire during some slow period or holiday weekend. I'm more than willing to lend a hand and would learn a lot.
I've got switches for lights, fan, Fantastic Vent cd/radio and power outlets. Behind the switches is a nest of wires, fuse blocks and Hellroaring isolator. Every year I think about rewiring this mess but figure one more winter and I'll buy a new van and do it right. This one more winter thing has been going on for several years though!
To do this right I'm looking at a gut job. I think I'll wait till I get a new van. If I can just get one more winter out of this one.
I'd be glad to help you mess up your van. If you are ever near my neighborhood and I'm home stop by. I've got 8' tall doors on my garage.
Awesome brother! Thanks for posting those, seriously.
Now who's got the remote Underdash Turtle Cam going so we can see apoplexy firsthand
Moot, I'm dead serious about helping do a rewire during some slow period or holiday weekend. I'm more than willing to lend a hand and would learn a lot. Offered the same to others for interior cab't work etc. I'm all set up, and quite knowledgeable about, woodworking and such, but my wiring skills need building.
He isn't kidding he is a great helper with equally great ideas!
Sent from my Fisher Price ABC-123.
I'm near La Crosse MN tonight, though hoping to catch one in the morning.
If you were in La Crosse, you weren't in Minnesota. If you were in La Crescent, you weren't in Wisconsin. If you were in both, you're all wet. A river separates the two cities and states.
Jackson, MN? Sounds like an Agco delivery.
So, you're using your cranking battery as if it were a deep cycle battery.I'm basically running a laptop and couple little gadgets off inverters. No fridge, no lights, etc etc. May add a vent later?
Well, you'll have to wire that other battery up to the alternator to get it charged. You do that with a battery isolator. That way, when the key is OFF and the engine isn't running, the aux battery is totally isolated from the cranking battery to prevent you from killing the cranking battery. When the key is ON and the engine is running, the alternator will charge the aux battery.Assuming standard alternator in GMC Savanna, can one just get the other battery, place in case/enclosure on the pass side...then wire the inverter?
No. Stop using your cranking battery as if it were a deep cycle battery. Not all batteries are created equal. Cranking (or starting) batteries are called that because that's what they are designed for - lots of amps in one whack to start the battery, and then used for vehicle accessories while the engine is running. Auxiliary batteries are deep cycle and are designed for constant low amp draws of laptop chargers and vent fans.A side.....could one not take this same setup....and run the slow charger off the said inverter, while charging a marine batt while driving down the road?
Now I'm confused. You said you are running a laptop and a few gadgets off an inverter. I assumed, possibly incorrectly, that the inverter is plugged into the 12-volt plug on the dash, or by some other connection to the cranking battery.No. There is only one battery under the hood right now. Trying to gather info on how to add the second one....for inside. Vans still in NY, not even brought it home yet.
Using an isolator or a separator is the only way to use a second battery that is charged by a single alternator. Well, you could just directly connect the aux battery to the cranking battery without an isolator of fusing, but that would be crazy.All of this is known. Sounds like what your saying is....the Sprinter I ran that had the inside battery (in which ran the inverter) was probably set up with isolator. Got it. Thanks
Turtle;664575]Now I'm confused. You said you are running a laptop and a few gadgets off an inverter. I assumed, possibly incorrectly, that the inverter is plugged into the 12-volt plug on the dash, or by some other connection to the cranking battery.
