Dave,
This is copy of my email to Chrysler today. I know this is long but it contains common complaints from other drivers.
Obviously there are still problems with the Sprinter. Maybe the Ford coming out sometime in 2006 will be the answer. They will be offering the same small diesel to be used in the new vehicle to replace the Expedition.
In checking my email I found this response from Chrysler, what a cop out.
[email protected]> (Add to address book)
Date: 2005/11/08 Tue PM 09:57:40 GMT
To: Brian Murray <
[email protected]>
Subject: Re: DaimlerChrysler Customer Assistance (KMM3347770V86046L0KM)
Dear Brian:
Thank you for your email.
We have received your email regarding your recent service experience.
I regret your dissatisfaction with the service you received and
appreciate the time and effort you took to bring this matter to my
attention.
We realize DaimlerChrysler's reputation depends in part on the quality
of service provided by our dealers. Because DaimlerChrysler dealers are
independently owned businesses, they are responsible for addressing
concerns directly related to their sales and service activities, as well
as their personnel. Although DaimlerChrysler does not have the
authority to resolve concerns related to dealer workmanship, service
scheduling, or repair pricing, you may want to pursue the matter
directly with dealership management for further resolution.
Information received from customers such as yourself enables better
evaluation of dealers' service activities. Your complaint will be
retained in the dealer's file.
Again, thank you for your email.
Sincerely,
Ahmad
Senior Staff Representative
DaimlerChrysler Customer Assistance Center
Hold down bolt broke allowing injector to pop out of head. Dealer ordered injector, refused to overnight at my expense. New injector put in after 5 days in shop. I picked up vehicle, noticed smoke from engine cover and returned to dealer. Tech looked at injector and told me it leaking at base of injector. Dealer claims fuel line bent and forcing injector out of place. New fuel line on indefinite backorder. I feel fuel line too weak to force properly seated injector out of place but I'm only the customer not certified tech. Tech "blows off" my concerns (Mike). I understand weird things happen and diagnosis is sometimes difficult but I think tech is taking the easy way out, after all he's not losing money if vehicle not on road.
I like sprinter but this is fourth strange breakdown causing lost time. One problem caused by tech (Marty) at Kayser Dodge failing to do authorized routine maintenance leading to a clogged fuel filter, finally replaced for first time at 85,000 miles.
In my opinion you have a problem with the short sightedness of your techs and your supply line is sorely inadequate. There is no reason for a routine part (fuel Filter) taking several days to get to a dealer. There is absolutely no excuse for a supply depot refusing to overnight a part when the customer is willing to pay for it
I have recently switched my routine service to Frank Boucher in Janesville. Their tech (Ollie) seems to be trustworthy and my experience so far is better than other dealers. They charge more but the service seems to warrant it. In fact I was trying to get to Janesville when injector broke loose and I had to be towed to local dealer.
In summation:
I do expedited freight and bought the Sprinter despite negative reports on internet (expeditorsonline.com). I love the roominess, gas mileage and handling of vehicle.
To date I've had:
• An EGR valve go out disabling vehicle in a snow storm on the expressway in downtown Detroit, with cargo aboard. This happening 4 days after Kayser assured me there was no problem with my EGR (recall check).
• At 60,000 miles (again with cargo) a wiring harness wore through on the top of the engine. Ollie said it was wire tied too tight to bracket. Again this happened 3 days after Kayser looked at vehicle because I had a starting problem.
• Lack of routine maintenance on dealers part causing several weeks of expense and running problems, try driving 2,000 miles at 60% power because nobody can diagnose problem.
• And now the problem with the injector.
I understand that things happen and am more understanding than most. Several years ago I was a partner in a used car dealership with repair facilities. I know first hand the things that can happen. I also recognize when things aren't as they should be. I've had more problems then should happen to a vehicle being sold as a reliable commercial vehicle. That’s bad enough but many of the techs working on my vehicle have taken a short sighted approach to repairs. IE: I'll try this; if it doesn't work will try something else. It's not an inconvenience to me if vehicle isn't running
The above will enter into my future purchases and recommendations to others.
Remember it’s not the problems that happen but how they are taken care of that influence a customers thoughts.
Brian "DOC" Murray
