DustyRoads
Do you have a pic of one on the engine?I was just reading an update about EGR valve's and failure's. Before you R&R your EGR take some spray cleaner (do not use brake parts cleaner, to hard on the plastics) and clean your MAP sensor. If your MAP senser gets plugged up with soot and dirt it will sometimes interfere with EGR functions. I can try and cut and paste the article on here but it might be to much. They say to clean the MAP sensor on a regular basis. All newer model trucks have them. They also say that keeping it clean helps fuel mileage by as much as 1/2 mpg.
Again use a regular MAP sensor spray cleaner, remove the MAP sensor, clean the entire valve and electronic connectors, let it dry thoroughly before reconnecting the plug.
Hope that helped some.
This is good on all diesels, not just Sprinters.
Thanks [email protected]
